John Williams (Antares 20E) World Record 1500 O&R claim pending
Old December 1st 09, 01:16 PM posted to rec.aviation.soaring
Dave Nadler
Default John Williams (Antares 20E) World Record 1500 O&R claim pending
Should be a new world record for 1500km O&R:
http://scottishglidingcentre.com/blog/
Way to go John !
PS: John also won overall European OLC championship in 2007:
http://www.onlinecontest.org/olc-2.0...=2007&c=C5&sc=
Old December 1st 09, 05:07 PM posted to rec.aviation.soaring
Darryl Ramm
On Dec 1, 4:16*am, Dave Nadler wrote:
Should be a new world record for 1500km O&R:http://scottishglidingcentre.com/blog/
Way to go John !
PS: John also won overall European OLC championship in 2007:http://www.onlinecontest.org/olc-2.0...tml?st=olc&rt=...
Great flight and a nice blog to read. Dave any idea how they deal with
ENL recording with the Antares or are they aerotowing with a sealed
engine?
Darryl
Old December 1st 09, 05:20 PM posted to rec.aviation.soaring
Dave Nadler
Way to go John !
engine?
Darryl
No idea, nor any idea why there's been a fuss about this.
Any engine operation is easily visible on the noise recording
in mine, either in the Volksloger or FLARM IGC files.
Its not "you must wear hearing protection or you will damage
your hearing" like other motor-gliders, but it is noisy enough...
See ya, Dave "YO electric"
PS: You can see this in any of my flights:
http://www.onlinecontest.org/olc-2.0...t=olc&pi=20684
Old December 1st 09, 08:00 PM posted to rec.aviation.soaring
Darryl Ramm
Way to go John !
engine?
Darryl
PS: You can see this in any of my flights:http://www.onlinecontest.org/olc-2.0....html?sp=2009&...
Dave
I had always assumed that the concern was more use of partial power.
Thanks
Darryl
ps. SAY AGAIN, WHAT WAS THAT ABOUT BEARING DAMAGE? :-)
Old December 2nd 09, 02:22 AM posted to rec.aviation.soaring
Dave Nadler
Way to go John !
engine?
Darryl
Dave
Still makes a racket, especially extending and retracting the pylon
(the hydraulic motor is running and the engine bay doors
are open)... Really its all quite silly !
Thanks
Darryl
Yup, I know some pilots like that. I don't bother with the headset for
airstarts, though I sometimes use it on the ground to be sure and
hear any radio calls...
Old December 3rd 09, 03:15 PM posted to rec.aviation.soaring
Dave Nadler
Way to go John !
John just posted some video from his flight.
Wow ! Ever seen your altimeter go up this fast ?
Some stats:
Declared 1551 km task
Average speed of 180.3 kph (97.4 kts).
This beat the old record of 177.3 kph (95,7 kts) set by Klaus Ohlmann
and Regis Kuntz.
Looks like a good start for John's first time in the Andes !
Best Regards, Dave "YO elcetric"
Old December 3rd 09, 08:21 PM posted to rec.aviation.soaring
Juan[_2_]
Way to go John !
Wow ! Ever seen your altimeter go up this fast ?http://scottishglidingcentre.com/blog/
It's actually an electric clock, runs off the big batteries :-)
Old December 8th 09, 10:37 PM
bagmaker bagmaker is offline
Senior Member
First recorded activity by AviationBanter: Aug 2005
I note that some speeds exceed 335kmh at altitudes above 10000ft.
Is the Antares rated for this or is it modified to reduce flutter?
bagger
Old December 9th 09, 09:30 AM posted to rec.aviation.soaring
johngalloway[_2_]
On Dec 8, 9:37*pm, bagmaker
bagger
bagmaker
Are you thinking that JDW was flying at 180kts IAS?
John Galloway
Old December 9th 09, 09:44 AM posted to rec.aviation.soaring
Bruce
johngalloway wrote:
On Dec 8, 9:37 pm, bagmaker
bagger
bagmaker
John Galloway
One assumes that tail winds and the like were involved...
Look at the ground speeds on Klaus Ohmlman's logs - Nimbus 4 with
sustained ground speeds in the 300km/h+ range! Same circumstances.
Bruce
Osaba to claim World Record for freestyle? distance John Gilbert[_2_] Soaring 5 August 1st 08 01:44 AM
World Record? Rabid enthusiast Soaring 1 March 18th 06 03:18 AM
New World Record Claim David Stevenson Soaring 2 July 12th 04 06:00 AM
Robin Williams World Peace Plan Fastglasair Home Built 15 April 21st 04 09:45 PM
100k triangle world record claim Stewart Kissel Soaring 0 November 11th 03 06:21 PM
