Crazy Buy of the Week
Old December 22nd 09, 01:39 AM posted to rec.aviation.soaring,recaviation.owning
Brian Whatcott
Default Crazy Buy of the Week
Wondering round the dimly lit used-goods store and there it was - a 40
cu ft nitrogen bottle. The store was in a closing down sale so the
price was right - for a current bottle and regulator.
But then of course, there was the little matter of a coiled air line, an
air chuck, a gas refill ($25), swapping the adapter to 1/4 inch pipe,
adding a quick connect, sketching out a 2 wheel trolley and buying a
pair of wheels etc., etc...
And the funny thing is: I know plane tires are often nitrogen filled,
but I can't imagine why. The bottled gas man said there is a growing
market for nitrogen from the local car dealers too. And that seems even
more unlikely.
Perhaps I'm biased - but I watched the Myth-busters doing their worst to
set a tire on fire, up to and including pouring gasoline over it
while making smoke with a muscle car - and failing!
Moreover, I have replaced at least one tire with perfectly usable tread
left: the Dallas ozone cracked the external case like you wouldn't believe.
Still, a toy is a toy.....
Merry Christmas!
Brian Whatcott
Altus OK
Old December 22nd 09, 02:35 AM posted to rec.aviation.soaring
Steve Leonard[_2_]
more unlikely.
Merry Christmas!
Brian Whatcott
Altus OK
Aircraft tires are usually filled with nitrogen, as on the big stuff,
the tire pressure is often well above 100 psi. Combined with big
volumes of air, and brakes that can be glowing cherry red (if not even
dripping a little metal every now and then), if one of them babies
lets go, you will have one heck of a fire in no time. If you add to
this the possiblity of a ruptured tire taking out a brake line and
spewing hydraulic fluid onto the brake along with air (oxygen) under
pressure, well, you can guess what will happen. So, the reason for
Nitrogen in aircraft tires is to remove the oxidizer from near the
ignition source, as even the roughly 20% oxygen in the air we compress
is enough to fuel a big fire on aircraft brakes.
On the other hand, that muscle car has big tires, and low pressure. I
seem to recall that the top fuel racers are running between 3 and 5
psi in their slicks. Big volume, but not much flow if one lets go.
The rubber on the tire melts at way below the ignition temperature, so
that is probably why the Myth Busters couldn't get it to catch fire.
So, why nitrogen for car tires? Easy Money. I tell you that if I
fill your tires with Nitrogen, it won't leak out as fast as air, so
you will get better gas mileage, and it will only cost you $45 for me
to do it, many will pay that $45. And since I am filling from a big
bottle that it costs me $25 to re-fill, and I can service probably 15
cars at $45 each, I can bring in $675 from a $25 re-curring cost, it
won't take me long to pay for my cart and be bringing in one of the
highest profit margins I have seen in a LONG time.
I will stick with the 78% nitrogen I get from my air compressor for my
tires.
Oh, yeah. And since Nitrogen is an inert gas, meaning it doesn't
support combustion, why do you think Shell is advertising "Nitrogen
Enriched Gasoline" to improve your mileage and increase the life of
your engine? You want to put something that won't burn in my gas, and
tell me you are doing a good thing? "Yes sir" he said with a smile on
his face.
Maybe DG can sell nitrogen for their tires? :-)
Steve Leonard
Wichita, KS
Old December 22nd 09, 02:33 PM posted to rec.aviation.soaring
Tony V
support combustion,
At the risk if being pedantic, that is not what inert gas means and
nitrogen is far from being inert. An inert gas is one that is
(essentially) chemically non-reactive like helium, argon, etc. Nitrogen
is easily reactive with NO2 possibly being the best known nitrogen compound.
Yeah, maybe someone should give them a call. LOL!
Tony V. LS6-b
Old December 22nd 09, 04:11 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Maybe DG can sell nitrogen for their tires? *:-)
Tony V. LS6-b
My bad, Tony. Inert is non-reactive, not "doesn't support
combustion".
But, I will still stick with my 78% nitrogen fill in my tires and
regular checking of the pressure.
Steve
Old December 23rd 09, 03:21 AM posted to rec.aviation.soaring
Eric Greenwell
support combustion,
Nitrogen is easily reactive with NO2 possibly being the best known
nitrogen compound.
That was what I thought, too, until I did a little research. According
to Wikipedia and the dictionary I consulted, Nitrogen is inert, as the
N-N bond in N2 is very strong. It is not a noble gas like helium, of
course. I think it is an error to say nitrogen (N2) is easily reactive.
NO2 is a strong oxidizer because the N-O bond is weak, but NO2 isn't N2.
Old December 23rd 09, 04:18 AM posted to rec.aviation.soaring
Brian Whatcott
...Nitrogen is an inert gas, meaning it doesn't
support combustion,
[Tony V]
nitrogen compound.
[Eric Greenwell]
Offering a middle way, Enc Brit (14th Ed.) mentions this:
"nitrogen gas is somewhat inert since the heat of dissociation of the
nitrogen molecule into atoms is large, but it can unite directly under
certain circumstances with several elements, including hydrogen,
oxygen, boron, silicon, lithium, magnesium, calcium, barium, titanium,
vanadium, tantalum, tungsten and manganese...."
Brian W
Old December 23rd 09, 01:40 PM posted to rec.aviation.soaring
Mike[_28_]
I prefer to fill my slowly leaking cars tires with N2O. I can't
explain it but it makes for a much more pleasant ride.
Old December 23rd 09, 03:53 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
support combustion,
[Tony V]
nitrogen compound.
[Eric Greenwell]
N2.
Offering a middle way, Enc Brit (14th Ed.) mentions this: "nitrogen gas
is somewhat inert since the heat of dissociation of the nitrogen
molecule into atoms is large, but it can unite directly under certain
circumstances with several elements, including hydrogen, oxygen, boron,
silicon, lithium, magnesium, calcium, barium, titanium, vanadium,
To be specific, lets look at the Haber Process, which is the basis of
nitrogenous fertiliser manufacture. It combines hydrogen with nitrogen
from the atmosphere. This reaction requires temperatures between 300 -
550C at pressures of 150 - 250 atmospheres and only takes place over an
iron oxide catalyst.
Silicon carbide is made by reacting nitrogen with silicon, but it only
reacts at 1300-1400 C.
That looks like a pretty inert, or non-reactive if you prefer, gas to me.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old December 22nd 09, 02:38 PM posted to rec.aviation.soaring
Richard[_9_]
more unlikely.
Merry Christmas!
Brian Whatcott
Altus OK
the tire pressure is often well above 100 psi. *Combined with big
lets go, you will have one heck of a fire in no time. *If you add to
pressure, well, you can guess what will happen. *So, the reason for
On the other hand, that muscle car has big tires, and low pressure. *I
psi in their slicks. *Big volume, but not much flow if one lets go.
So, why nitrogen for car tires? *Easy Money. *I tell you that if I
to do it, many will pay that $45. *And since I am filling from a big
tires.
Oh, yeah. *And since Nitrogen is an inert gas, meaning it doesn't
your engine? *You want to put something that won't burn in my gas, and
tell me you are doing a good thing? *"Yes sir" he said with a smile on
his face.
Steve Leonard
Wichita, KS
If you buy your auto tires at Costco they fill with nitrogen and put a
nice green cap on the filler.
Richard
www.craggyaero.com
Old December 23rd 09, 01:47 AM posted to rec.aviation.soaring
Brian Whatcott
Richard
www.craggyaero.com
On the other hand, if you should fix a slow leak on your car with some
of the fix a flat goo cans, the propellant gas is butane or propane.
They thoughtfully provide a wheel sticker to warn your mechanic to
take care when removing the case after using the product though....
Brian W
Crazy loons raulb Soaring 30 November 21st 07 02:42 PM
This guy is a crazy C.D.Damron Home Built 3 December 5th 05 05:42 AM
crazy question alf Home Built 6 November 15th 04 07:45 PM
gods must be crazy bryan chaisone Home Built 8 November 7th 04 11:22 PM
drive shitbyrd crazy week Randall Robertson Simulators 0 January 2nd 04 01:34 PM
