Easa grounds two parachute types for manufacturing defects
Old January 22nd 10, 03:39 PM posted to rec.aviation.soaring
cernauta
Default Easa grounds two parachute types for manufacturing defects
EASA has issued an Airworthiness Directive concerning some parachutes
produced between 4 april 2008 - 15 january 2010. The defect is a
serious one: the canopies might not deploy.
Types:
Slimpack t204 and Thinback t104, serial numbers from 41495 to 41776.
in this online catalog, in the first two lines, two examples of the
concerned parachutes
(no pun intended on the seller, it's just for illustration)
http://www.friebe.aero/Survival_Equi...6,0,0,0,2.html
the EASA A.D.
http://www.google.it/url?sa=t&source...tNxNkIaPtMn0gQ
Aldo Cernezzi
Old January 22nd 10, 10:28 PM posted to rec.aviation.soaring
Peter Scholz[_2_]
Types:
the EASA A.D.
Aldo Cernezzi
You can find the safety Information Bulletin mentioned by the EASA
document he
http://www.rettungsfallschirme.de/Si...mitteilung.pdf
It is in German, and basically instructs the owner of the affected
parachute to send the release handle only together with the papers of
the parachute to the adress mentioned in the document. It also asks to
include stamps for sending it back to you, which probably is not very
practical for someone living outside of Germany. There is also an E-Mail
adress included to contact in order to discuss this matter beforehand.
Peter Scholz
Old January 24th 10, 01:33 AM posted to rec.aviation.soaring
Walter[_2_]
This is the English version:
http://www.rettungsfallschirme.de/Si...tteilung_E.pdf
EASA Vs FAA glider[_2_] Soaring 5 December 26th 09 03:38 PM
USN grounds 39 P-3s over faulty wings Marco P.J. Borst Naval Aviation 3 January 6th 08 09:09 AM
EASA glider imports Sleigh Soaring 0 June 16th 07 12:54 AM
Softie parachute EASA type certificate bjorn Soaring 2 January 25th 07 07:10 PM
JPI 800 & GMA 340 into C206 in EASA countries? Jouni Laukkanen Owning 3 August 4th 05 08:30 AM
