Tow planes and transponders
Old February 14th 10, 10:00 PM posted to rec.aviation.soaring
Andy[_1_]
Default Tow planes and transponders
Worldwide, what exemptions from transponder equipage apply to glider
tow planes (assuming built and certified with an electrical system)?.
How typical is it that tow planes are not equipped with a mode C or
mode S transponder?
Andy
Old February 14th 10, 11:02 PM posted to rec.aviation.soaring
BT[_3_]
In the US, there are no exemptions that I am aware of for Tow Planes.
14CFR 91.215 applies. It is rather extensive.
91.215 (b) All aircraft in airspace described in (b)(1) through (b)(5) must
have Mode 3A, C or Mode S.
(b)(1) All aircraft in Class A, B or C
(b)(2) All aircraft within 30nm of Appdx D airports .. (Mode C Veil) up to
10,000MSL
(b)(3) starts the exemptions..
(b)(4) above the ceiling of Class B, Class C up to 10,000MSL
(b)(5) All aircraft (except gliders, balloons, no electrical power).. etc
(b)(5)(I) above 10,000MSL
Bottom line, any aircraft , outside of 30nm from a "Class B airport" and
below 10,000MSL (or 2500AGL if higher) would not need a transponder.
A tow plane is not exempt just because it is towing.
If any aircraft flying more than 30nm from a Class B airport and outside of
Class C airspace, and stays below 10K, no transponder required.
"Andy" wrote in message
mode S transponder?
Andy
Old February 15th 10, 01:27 AM posted to rec.aviation.soaring
BT[_3_]
May we ask why the question?
If your tow location is more than 30nm from a Class B airport and tow stays
below 10K MSL, then transponder is not required.
We are within the 30nm ModeC Veil and need a transponder. When we know it
has failed, we have been able to call and get approval to tow, remaining
within 4nm and 5K AGL of the satellite airport.
BT
mode S transponder?
Andy
Cheap transponders Ramy Soaring 2 March 17th 09 02:35 PM
transponders in EU Sandro Soaring 2 February 2nd 07 01:02 PM
Confused re transponders and ADS-B Andrew Gideon Piloting 6 June 27th 06 01:49 AM
Transponders [email protected] Home Built 2 March 2nd 05 02:39 AM
Transponders Mil80C Soaring 64 February 12th 04 05:46 PM
