Glide Navigator 2 technical question (V2 and V3)
Old February 19th 10, 03:58 AM posted to rec.aviation.soaring
Scott Alexander[_2_]
Default Glide Navigator 2 technical question (V2 and V3)
I'm going through the setup on glider navigator 2 on my IPAQ 2215.
When I select the polar data it does not ask for the speed at V2 and
V3. It does ask me for max l/d info and V1 speed.
Anyone know how I can enter the V2 and V3 speed?
Thanks in advance!!
SA
Old February 19th 10, 04:12 AM posted to rec.aviation.soaring
Paul Remde
Hi Scott,
GN II doesn't use the 3-points method to determine the polar. It uses the
V1 (best L/D) speed and glide ratio and the V2 speed (speed at 2 m/s sink).
It may be that you didn't see the "Next" button at the bottom of the screen
when done entering the V1 data. It is the same polar definition method used
by all Cambridge products.
You can find data for polars for many gliders (in several formats) he
http://www.cumulus-soaring.com/polars.htm
Feel free to call me if you need more help with this.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
"Scott Alexander" wrote in message
Thanks in advance!!
SA
New Version of Glide Navigator II Available Paul Remde Soaring 3 February 2nd 08 08:49 AM
Glide Navigator II v2.41 problems charlie foxtrot Soaring 2 April 4th 06 02:32 PM
Glide Navigator II help [email protected] Soaring 7 March 24th 06 04:16 PM
New version of Glide Navigator II Available Paul Remde Soaring 0 March 15th 06 03:43 PM
Bugs in Glide Navigator II David Martin Soaring 0 July 28th 03 04:35 PM
