Master clyinder
Old April 3rd 10, 01:20 AM posted to rec.aviation.soaring
Default Master clyinder
We are looking for a new wheel brake master cylinder for our Grob 103
Twin Two Acro. The one that is in there is "Magura" brand, but no
part number. This is obviously from a motorcycle, circa 1980, but we
can't seem to cross reference. Some machining work was done on it to
convert to fit a glider instead of handle bars.
I have looked at several Grobs, and some have different master
cylinders.
Can anybody help with finding a replacement part?
Thanks
Cookie
Old April 3rd 10, 01:35 AM posted to rec.aviation.soaring
vontresc
It might be a BMW brake. I have a Magura master cylinder on my '82
R65. I bet if you took it to the local BMW motorcycle shop or to
someone who knows vintage Beemers, they could ID it.
Pete
On Apr 2, 6:20*pm, "
Twin Two Acro. *The one that is in there is "Magura" brand, but no
part number. *This is obviously from a motorcycle, circa 1980, but we
can't seem to cross reference. *Some machining work was done on it to
cylinders.
Thanks
Cookie
Old April 3rd 10, 03:48 AM posted to rec.aviation.soaring
SoaringXCellence
Pete
cylinders.
Thanks
Cookie- Hide quoted text -
- Show quoted text -
If you don't get a answer by Sunday evening I'll be able to help as I
will have my G103A in the shop for inspection and I can get the info
off mine.
Old April 3rd 10, 05:02 AM posted to rec.aviation.soaring
Grider Pirate
On Apr 2, 4:20*pm, "
cylinders.
Thanks
Cookie
Might check out this site
http://www.pingelonline.com/magura_master_cylinder.htm
Old April 3rd 10, 05:11 AM posted to rec.aviation.soaring
Grider Pirate
cylinders.
Thanks
Cookie
.... or here
http://www.rockypointcycle.com/Merch...ory_Co de=N11
The Magura is available in 13mm piston and 16 mm piston.
Master cylinders [email protected] Home Built 25 July 29th 08 03:08 AM
master warning Kevin Simulators 1 July 27th 06 08:28 PM
Master Buss Bar? ccwillwerth Home Built 18 January 20th 06 03:32 AM
Master Jet Base MICHAEL OLEARY Naval Aviation 24 April 22nd 05 08:00 AM
RC Plane Master Steve Simulators 0 December 20th 03 03:40 PM
