Release from tow, good procedure?
Old April 15th 10, 11:59 PM posted to rec.aviation.soaring
glider[_2_]
Default Release from tow, good procedure?
Are we teaching the sailplane pilot to look for traffic to the left of
the towplane. There could be traffic just below and to the left that
the towpilot may not see.
If someone is low, to the left of the Pawnee do we hold on a bit
longer?
Your thoughts?
GA
Old April 16th 10, 12:29 AM posted to rec.aviation.soaring
Fred[_4_]
*If someone is low, to the left of the Pawnee do we hold on a bit
longer?
*Your thoughts?
*GA
We teach our students to clear to the right of the glider, then left
and below the tow plane before we release.
Fred Blair - CFIG
Greater Houston Soaring Association
Old April 16th 10, 01:52 AM posted to rec.aviation.soaring
BT[_3_]
We do the same, unless the Tow pilot has already called on the Radio.. "Tow
has UF in sight".
"glider" wrote in message
longer?
Your thoughts?
GA
Old April 16th 10, 02:27 AM posted to rec.aviation.soaring
Grider Pirate
has UF in sight".
longer?
Your thoughts?
GA- Hide quoted text -
- Show quoted text -
Are you pickin on me? ;-p
Old April 16th 10, 04:25 AM posted to rec.aviation.soaring
BT[_3_]
"Grider Pirate" wrote in message
"Tow
has UF in sight".
longer?
Your thoughts?
Naw.... just knew you'd be watching the forum... LOL
Old April 18th 10, 03:51 PM posted to rec.aviation.soaring
Martin[_5_]
That's how students are taught at my club...look to the right for you,
then look to the left for the towplane.
Mind you, we're also taught to look around throughout the tow and
afterwards, not just prior to release
Land Out Procedure Mike McCarron[_2_] Soaring 4 July 7th 08 01:57 PM
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good Excelsior Home Built 0 April 22nd 05 02:11 AM
Procedure Turn Bravo8500 Instrument Flight Rules 65 April 22nd 04 04:27 AM
Unusual Procedure at DFW Toks Desalu Piloting 9 December 17th 03 06:27 PM
OAK arrival procedure ROBIN FLY Instrument Flight Rules 5 October 1st 03 04:05 AM
