Ka-6 Tuning
Old May 3rd 10, 11:28 PM posted to rec.aviation.soaring
vontresc
Default Ka-6 Tuning
Ok help me spend more time putzing around with my glider. I am in the
process of redoing the aileron seals on my Ka-6Cr, and it got me to
wonder about the rudder and elevator. Right now the gap on the
elevator is not sealed off at all although the trim tab on mine does
have a mylar gap seal. The rudder isn't sealed off either.
Have any of you done this, and do you have suggestions on how to seal
off these gaps?
Also any other things to look at where I can make small improvements?
Thanks
Peter
Old May 3rd 10, 11:34 PM posted to rec.aviation.soaring
Tony[_5_]
Default Ka-6 Tuning
off these gaps?
Thanks
Peter
pete i used 3/4 x 1/2 inch open cell foam with one of the 3/4" wide
sides sticky backed. one strip on the airplane side and another stip
on the control surface side. seems to have worked fine on the
cherokee.
Old May 4th 10, 04:01 AM posted to rec.aviation.soaring
Tony[_5_]
Default Ka-6 Tuning
off these gaps?
Thanks
Peter
sides sticky backed. *one strip on the airplane side and another stip
cherokee.
ORR you could just buy a Cherokee or move to Kansas!
Problems tuning nav radios cm Simulators 0 January 4th 05 01:29 AM
Need CO analyzer for motorglider tuning Eric Greenwell Soaring 5 November 23rd 04 08:44 PM
Tuning up for Uvalde at Marfa David Kinsell Soaring 1 August 12th 04 05:56 AM
Tuning up FS9 Dan Moos Simulators 3 September 14th 03 10:18 PM
Tuning In and Hot Take-Offs Art Cline Rotorcraft 0 July 28th 03 01:32 PM
