New Soaring PNA Available
Old May 10th 10, 08:22 PM posted to rec.aviation.soaring
Junior Team 2007
Default New Soaring PNA Available
http://silentflight.com/index.php?op...=1 &Itemid=16
Al - Tell us what it can do!
Old May 11th 10, 12:06 AM posted to rec.aviation.soaring
On May 10, 12:22*pm, Junior Team 2007
http://silentflight.com/index.php?op...&Itemid=16&vmc....
Well its a CE5 device with a 12 Channel GPS in it.
You can run on it what ever you want on it bottom line.
I am currently running the LK8000 beta test software on it currently
and really like the software
What is interesting is when testing the unit the GPS is accurate
enough IMHO to dispense with all the crazy cabling needed to talk to a
vario system.
The net result its the unit works really well as a self contained unit
all you need to do it connect the unit to 12V power.
More info and photos on http://silentflight.com
Oh and the price is right.. so come on down......
Al
Old May 11th 10, 03:29 AM posted to rec.aviation.soaring
Bastoune
Two quick questions:
What is the screen resolution?
Is there a serial port? If so, has anyone tried to interface with
flight computer or vario?
Thanks!
Old May 11th 10, 05:12 AM posted to rec.aviation.soaring
Thanks!
Screen res is 800x480 with a 533mhz CPU.
There is a port marked COM that we will be experimenting with to see
if it will take NMEA.
Or you could buy (and we will be supplying shortly) an integration
cable/charging cable that will let you connect an external NMEA feed.
Al
Old May 11th 10, 05:53 AM posted to rec.aviation.soaring
Thanks!
Sunlight readability compared to an Ipaq 3850?
Eric Greenwell - Washington State, USA (netto to net to email me)
Much better however its hard to define as everyone has their own
opinions about readability.
What is more important is the readability with more screen real
estate.
Cheers
Al
Old May 11th 10, 03:56 AM posted to rec.aviation.soaring
toad
On May 10, 7:06*pm, "
vario system.
More info and photos onhttp://silentflight.com
Al
What I really want to know. Does it come with a plastic Jesus ?
Old May 11th 10, 05:13 AM posted to rec.aviation.soaring
vario system.
Al
Tell you what Toad you buy one I will send you a plastic Jesus with
it.
Al
Colorado Soaring Pilots/SSA Governor 2007 Seminar and 2006 Soaring Awards Banquet Frank Whiteley Soaring 0 February 15th 07 04:52 PM
The Soaring Server is dead; long live the Soaring Servers John Leibacher Soaring 3 November 1st 04 10:57 PM
Soaring Server/Worldwide Soaring Turnpoint Exchange back online John Leibacher Soaring 0 June 21st 04 05:25 PM
Soaring Server - Worldwide Soaring Turnpoint Exchange John Leibacher Soaring 0 June 19th 04 04:57 PM
World Champion Soaring Pilot To Speak at Sky Soaring John DeRosa Sky Soaring Chicago IL Soaring 0 May 14th 04 09:02 PM
