Fiberglass Wing Cuff
Old May 13th 10, 05:07 PM posted to rec.aviation.soaring
vontresc
Default Fiberglass Wing Cuff
Anyone got good advice on building a fiberglass wing cuff? I realized
last week that I really need to get rid of the metal wing stands with
sharp corners waiting to punch holes in my Ka-6 wings. So far my plan
was to mold the cuffs on the wing using west systems epoxy. The
question I have is what weight of cloth would you suggest, and how
many layers would be required.
Thanks
Pete
Old May 13th 10, 05:53 PM posted to rec.aviation.soaring
sisu1a
So far my plan
While West Systems is fine epoxy and all, if you can get real aircraft
resin/hardener is it MUCH nicer to work with. The L285 system is the
nicest stuff I've ever worked with and kinda smells like pretzels when
it's mixed and even again later when sanded. Of course if you actually
*like the smell and toxicity of highly outgassy boat resin than have a
ball!
Sorry to not answer your question, I nearly always wind up picking the
hardest way to do stuff and want to hear the other opines too...
-Paul
Old May 13th 10, 06:56 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
was to mold the cuffs on the wing using west systems epoxy. The question
I have is what weight of cloth would you suggest, and how many layers
would be required.
Don't forget to put overwide carpet or felt on the wing first, then the
release film and lay up the glass over that.
IMO you could do a lot worse than give CST a call, tell them what you're
doing and ask what glasscloth/chopped strand mat, release film and epoxy
they'd recommend. They sell Pro-set, MGS and West systems epoxy.
Look at and measure wing cuffs at your local field to get a feel for how
wide the cuff needs to be and how thick you'll need to make it before you
talk to them, or any other supplier for that matter. Talk to the owners
to find out what they'd want to change if they replaced their wing cuffs.
CST are at Tehachapi: http://www.cstsales.com/
If you speak to Matt or Gail tell them I sent you. Matt is a keen model
flyer and got into selling composite materials through sourcing them to
build his competition models. They later branched out into supplying the
custom car folks and Hollywood film set builders, so they will understand
making things the size of wing cuffs.
martin@ | Martin Gregori
gregorie. | Essex, UK
org |
Old May 13th 10, 07:14 PM posted to rec.aviation.soaring
Grider Pirate
On May 13, 9:56*am, Martin Gregorie
would be required.
CST are at Tehachapi:http://www.cstsales.com/
martin@ * | Martin Gregori
org * * * |
While I use the MGS epoxies for repair work, I wouldn't spend the big
bucks for it to make wing cuffs. Wayne Paul sent me a link (which I
will try to find when I get home tonight) for an outfit in Florida
that sells epoxies that are about 1/3 the price of the MGS epoxy.
They also sell the super thick/coarse glass cloth and mat that you
will want to use. See Wayne's article on the SoarIdaho site under the
Scheder gliders section. He constructs a tail dolly for his glider,
and many of the techniques are applicable to your (vastly simpler)
wing cuffs.
Old May 13th 10, 07:19 PM posted to rec.aviation.soaring
mike
would be required.
link for glass and epoxy
http://www.uscomposites.com/
Use it for all of my sailplane misc stuff like wing and tail dollies
etc.
Good company.
org * * * |
will want to use. *See Wayne's article on the SoarIdaho site under the
Scheder gliders section. *He constructs a tail dolly for his glider,
wing cuffs.
Old May 13th 10, 07:52 PM posted to rec.aviation.soaring
Tim Taylor
would be required.
org * * * |
wing cuffs.
Probably Raka
http://www.raka.com/index.html
Great Epoxy at about the best price in the US. Great for all types of
projects.
I have bee using it for years on may different projects. Most cuffs
are thick so a layer or two of chopped between a weave would work well
and not require 10 layers of weave.
Old May 13th 10, 08:33 PM posted to rec.aviation.soaring
Grider Pirate
Thanks
Pete
Found the link from Wayne Paul:
http://www.shopmaninc.com/index.html
Old May 14th 10, 12:51 AM posted to rec.aviation.soaring
David Walsh[_2_]
Pete,
Wayne Paul has a nice page on how to build a tail dolly, not
specifically what
you are asking about, but you might pick up some general tips.
http://www.soaridaho.com/Schreder/Co...lly/index.html
More specifically, check out another of Wayne's pages. On the page,
I think the "carrier links" are exactly what you are looking for.
http://www.soaridaho.com/Schreder/Co...rier/LWT-3.htm
And lastly, Lane Bush has a few photos of a wing cuff for a single man
rigger,
but you should still see the basic strategy. Check out the Cirrus,
Yahoo
news group, photos, #209 Project photo albums, Wing Rigger Mold.
Hope this gets you going.
Regards,
David Walsh
Thanks
Pete
Old May 14th 10, 01:32 AM posted to rec.aviation.soaring
vontresc
Thanks for all the info. Can anyone give me some more info on the
"tooling cloth" that is mentioned in Wayne Paul's tail dolly build?
I was just going to use West Systems because I can get it locally, and
have used it in the past. I'll probably take your advice, and go with
another epoxy though.
Pete
On May 13, 5:51*pm, David Walsh wrote:
Pete,
Wayne Paul has a nice page on how to build a tail dolly, *not
specifically what
you are asking about, but you might pick up some general tips.http://www.soaridaho.com/Schreder/Co...lly/index.html
I think the "carrier links" *are exactly what you are looking for.http://www.soaridaho.com/Schreder/Co...rier/LWT-3.htm
rigger,
but you should still see the basic strategy. *Check out the Cirrus,
Yahoo
Regards,
David Walsh
Thanks
Pete
Old May 14th 10, 02:16 AM posted to rec.aviation.soaring
Tim Taylor
Pete
Pete,
specifically what
rigger,
Yahoo
Regards,
David Walsh
Thanks
Pete
Tooling cloth is usually a much heavier cloth that minimizes the
number of layer you have to put down.
http://www.wicksaircraft.com/Wicks/P...eMaterials.pdf
Look at page 56, BIAXIAL & TRIAXIAL CLOTH. You can get it up to 22 oz
per sq yard. I would guess you could get away with 3 to 4 layers of 22
oz for a wing cuff if it is fully closed and slides over the end of
the wing.
this guy doesn't believe in fiberglass rwhughe Aviation Photos 0 February 27th 10 07:05 AM
Fiberglass revisited Lou Home Built 3 October 31st 06 01:50 PM
fiberglass tapes Lou Home Built 7 October 22nd 06 08:30 AM
Fiberglass seperation Lou Home Built 7 September 25th 06 05:03 AM
Fiberglass vs. Fabric Lou Home Built 35 July 6th 06 06:08 PM
