TINSFOS question
Old May 21st 10, 03:06 AM posted to rec.aviation.soaring
Brad[_2_]
Default TINSFOS question
am curious about 16.5m wing extensions, are ailerons usually
incorporated into these, or if the existing aileron/flaperon ran full
span to begin with, would the roll rate suffer if the extension did
not include the control surface?
BTW...................Mr. Moffat inspired me when I saw him sawing the
tip of his big Cirrus and gluing on that tip extension!
also................I really like the polyhedral look, is that pretty
typical for modern extensions?
Brad
PS..........TINSFOS was the big debate during the Russia SIFOW
controversy!
Old May 21st 10, 04:26 PM posted to rec.aviation.soaring
Grider Pirate
Brad
controversy!
Okay, I used http://www.acronymfinder.com/There-i...(TINSFOS).html
to find out what TINSFOS is, what is SIFOW?
Old May 21st 10, 05:06 PM posted to rec.aviation.soaring
Tony[_5_]
Brad
controversy!
Okay, I usedhttp://www.acronymfinder.com/There-is-No-Substitute-for-Span-(gliding...
to find out what TINSFOS is, what is SIFOW?- Hide quoted text -
- Show quoted text
Span Is FOr Wimps ?
Old May 21st 10, 06:02 PM posted to rec.aviation.soaring
Grider Pirate
Brad
controversy!
- Show quoted text
Span Is FOr Wimps ?- Hide quoted text -
- Show quoted text -
I came up with Span Is For Old Wimps, but you can reach ISBT
(Insufficient Span Ballistic Trajectory) if you take it too far.
Old May 21st 10, 10:06 PM posted to rec.aviation.soaring
noel.wade
Brad -
IIRC, early ships with 16.5/16.6 extensions had no additional control
surfaces.
Ships with 17+ tips tended to have an aileron extension of some kind.
As far as I know, only later-model ships have tended to have the
polyhedral, and from what I understand its more about preventing
wingtip scrapes (easier to leave the wingtip skid on the non-removable
part of the wing) or requiring a beefy spar in the tip exension (to
handle ground loads) than anything else.
Enjoy,
--Noel
Old May 22nd 10, 03:07 AM posted to rec.aviation.soaring
Brad[_2_]
On May 21, 1:06*pm, "noel.wade" wrote:
Brad -
surfaces.
Enjoy,
--Noel
thanks Noel, that's sort of my strategy. I added the wing tip wheel
fairing on the left wing and the plan is to add an extension someday,
angle it a bit to allow for the wheel to still work, but that
polyhedral just plain looks cool!
Brad
Old May 23rd 10, 11:31 PM posted to rec.aviation.soaring
Brad
controversy!
Extending the ailerons allows the airfoil to be consistent to the tip
which helps maintain expected spanwise lift distribution.
It DOES complicate things.
FWIW
UH
Old May 24th 10, 05:06 AM posted to rec.aviation.soaring
Steve Leonard[_2_]
If the plane has flaps, and you don't run the ailerons on out, you
probably won't be able to use all or any of the negative flap for
higher speed running. The LS-3/17 manual says "Thou Shalt Not Use ANY
negative flap if you installest thy long tips." They didn't put
ailerons on their tips. The Nimbus 3 manual says "Thou shalt limit
the flap travel to -2 (block thy "S" position) if you increase the
span from 24.5 to 25.5 meters. Why? As Hank said, if you run the
flaps up and don't have aileron (interconnected with the flaps, of
course) on the extension, the tips pick up a LOT of load, as they are
at a much higher angle of attack than the rest of the wing.
If the plane does not have flaps, adding aileron will only complicate
your life.
The poly wing actually helps the plane "groove" a bit more in
thermals. It can also have the benefit of pushing the downwash field
down and outboard at the tips, potentially providing a small increase
in effective span. Or maybe, less of a decrease in effective span as
compared to a planar wing. And if your tip chord gets really small,
it makes it so you are less likely to drag three feet of wing on the
ground if a wing goes down on takeoff.
My nickels worth,
Steve
Old May 24th 10, 11:24 PM posted to rec.aviation.soaring
higher speed running. *The LS-3/17 manual says "Thou Shalt Not Use ANY
negative flap if you installest thy long tips." *They didn't put
ailerons on their tips. *The Nimbus 3 manual says "Thou shalt limit
span from 24.5 to 25.5 meters. *Why? *As Hank said, if you run the
your life.
thermals. *It can also have the benefit of pushing the downwash field
in effective span. *Or maybe, less of a decrease in effective span as
compared to a planar wing. *And if your tip chord gets really small,
My nickels worth,
Steve
I was once told, by someone who is likely to know, that S-H put the
poly in the tips to keep them from ground contact loads and then
discovered it made the glider fly better. Not sure if this is true,
but it makes sense. Driving the outer aileron in one direction(up)
with spring down can allow poly and disconnects the mass which
simplifies the flutter issue-provided extension ailerons are properly
mass balanced.
In any case, they look cool.
UH
Old May 24th 10, 11:52 PM posted to rec.aviation.soaring
Brad[_2_]
your life.
My nickels worth,
Steve
mass balanced.
UH
I suppose if I can make the whole damn glider, I can make tips with
control surfaces! But.............that's down the road a ways. I
agree, they look really cool and the polyhedral will make good use of
the wing tip wheel I installed.
Brad
I want to ask you the most important question of your life. The question is: Are you saved? It is no gasman Soaring 0 August 26th 05 07:39 PM
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good Excelsior Home Built 0 April 22nd 05 02:11 AM
Question about KLN-89B Casey Wilson Instrument Flight Rules 9 March 8th 04 09:07 PM
Question about Question 4488 [email protected] Instrument Flight Rules 3 October 27th 03 02:26 AM
TINSFOS - looking for a Nimbus T in Europe somewhere tango4 Soaring 0 October 2nd 03 10:14 PM
