Any Info on Hipec? No Rib Stitching?
Old November 14th 03, 07:43 AM
bling bling
Default Any Info on Hipec? No Rib Stitching?
I wonder if anyone has experience with the Hipec fabric covering system? It
claims that no rib-stitching is required for most reasonably loaded wings.
This seems remarkable, to say the least.
It's sold by Falconar Aviation http://www.falconaravia.com/
Regards,
G.
Old November 14th 03, 08:48 PM
Ed Sullivan
"bling bling" wrote in message ...
Regards,
G.
That system has been used for years on many European designs. My
Jungster II has no rib stitches. The cap strips are an inch wide and
in my case the fabric was attached width Goodyear Pliobond. It was
brushed onto the unvarnished cap strips then the fabric applied and
shrunk after which acetone or MeK is brushed on the outside to draw
the Pliobond up through the fabric. It is then coated with Nitrate
followed by Butyrate dope.
I was a little dubious at first, so I made up some small test panels
and applied fabric with Stits Poly-Tak, Sureseam, and the Pliobond.
The first two exhibited no peel strength and came off effortlessly,
while the Pliobond tore the cap strip to bits.
My Jungster which has done a goodly amount of aerobatics is nearly
twenty years old and seems as sound as ever. This has been by
experience, but I would recommend that you seek other advice as well,
but whatever you do don't ask Ray Stits.
Good Luck, Ed Sullivan
Old November 14th 03, 10:39 PM
bling bling
Thanks, Ed.
Your experience sounds good, but there are a couple of differences with the
Hipec system. Hipec does not make use of any third-party glue, like
Pliobond. It recommends that you simply brush on the Hipec Sun Barrier
product onto the fabric-- like you would the Stits Poly Brush -- and it
soaks through into the capstrip and bonds the fabric in place.
It also recommends that the wood be varnished with epoxy varnish instead of
left bare. And, most curiously of all, Hipec says it doesn't matter how wide
the capstrip is. They have an illustration showing capstrips from very thin
to wide and claim that it makes no difference.
I've heard of some people who have finished their planes with Hipec, and
they seem to be well regarded, but I haven't seen any examples or heard
directly from owners.
Regards,
Gordon.
"Ed Sullivan" wrote in message
om...
It
wings.
Regards,
G.
Old November 15th 03, 02:06 AM
Blueskies
What about a recovering job or repairs in general...
Dan D.
Thanks, Ed.
Regards,
Gordon.
om...
It
wings.
Regards,
G.
Old November 16th 03, 09:57 PM
Ray Toews
I have used Hipec on several ULTRALITE designs and found it very easy
to use.
I have used most systems, Randolph, Stits, Ceconite 7600 (what
happened to it?) and prefer the Hipec method.
It is easy, quick and rugged, stinks to high heaven but ventilate or
use respirator and you can get a nice finish with a foam roller in a
clean room. It is a bit tricky to spray, I had a friend with a body
shop spray it and made a mess which I cleaned up very nicely with a
roller.
I dismantled an aircraft which had 1/2 inch aluminum ribs that had
been Hipeced and the fabric was a real bitch to pull off the ribs.
Dan D.
Thanks, Ed.
Regards,
Gordon.
om...
It
wings.
Regards,
G.
Old November 19th 03, 10:24 PM
bling bling
Thanks for your reply and info, Ray.
What do you think about using Hipec on a larger aircraft, such as 1800
pounds groos weight?
I'm still kind of skeptical about the Hipec claim that no rib stitching or
mechanical fasteners are required. And what about the fact that Dacron
fabric is very difficult to stick to?
Regards,
Gordon.
Ray Toews wrote in message ...
to use.
roller.
Dan D.
Thanks, Ed.
instead of
wide
thin
and
Regards,
Gordon.
om...
system?
It
wings.
Regards,
G.
Info on a P-51 mustang called "Spare Parts" eg Home Built 3 October 28th 03 03:02 AM
Defiant Info David Culbertson Home Built 0 October 13th 03 06:06 AM
SNS2 Guppy Info Wanted AKAVIE Home Built 3 October 1st 03 06:38 AM
Pitts Special - info and photo's required. Darryl Gibbs Aerobatics 1 August 5th 03 09:05 PM
