tap for lycoming exhaust port
Old August 1st 10, 05:15 AM
LukeCS LukeCS is offline
Junior Member
First recorded activity by AviationBanter: Aug 2010
Default tap for lycoming exhaust port
I have had to reface the exhaust port on my number 1 cylinder. The directions for the refacing tool say I should clean the threads of the hole the exhaust studs go in but I can not find a tap to match the threads nor can I find a die to match the threads on one of the new exhaust studs on the side that threads into the cylinder. The threads for the flange side are different but both are 5/16. Where can I find a tap and or die? Thanks
Old August 2nd 10, 10:58 PM posted to rec.aviation.owning
Herb Feldman
Try this link, www.HermansCentral.com,
Herb
"LukeCS" wrote in message
LukeCS
Tuned exhaust for the Lycoming 0320 Stuart & Kathryn Fields Rotorcraft 4 June 21st 08 05:09 AM
tuned exhaust for a lycoming 0320 Stuart & Kathryn Fields Home Built 3 May 20th 08 04:55 AM
On the job with a port trucker: Port truckers like Marvin Palacios are the tiniest players in a prosperous global transport chain. But while big companies cash in, drivers barely make Goteborgbank Naval Aviation 1 October 13th 07 03:44 PM
On the job with a port trucker: Port truckers like Marvin Palacios are the tiniest players in a prosperous global transport chain. But while big companies cash in, drivers barely make Goteborgbank Piloting 2 October 2nd 07 11:12 PM
Lycoming 0-320 Exhaust studs working loose Mike Spera Owning 9 May 26th 07 04:25 AM
