Any suggestions for self-launch two-seater glider at 100 000 EUR
range? My current list: ASH-25M: ASH25 self launchers tend to start from EUR 160 000 unfortunately. Do you know how sophisticated is the engine operation? Is there any flight manual available in the net? (my brief look at Duo Discus T engine starting procedure was quite a bad surprise, is ASH-25M the same?) DG-1001M: looks like ideal bird, but brand new and probably very expensive? ASK-21 Mi: Trainer, I would like to get better XC performance. New model and a bit expensive, too. Nimbus 4DM: Looks quite expensive and non impressive. "No aerobatics, even no intentional spins" in the documentation is not attractive at all. Janus CM: very rare species, does anybody suggest? Grob G103 Twin III SL: Also no clue how good can it be Stemme S10: quite expensive and I am not quite sure how good for thermalling it really is. More for touring. Thank you! Teet www.purilend.ee |
http://www.desertaerospace.com/bonusjet.html
'nuff said. Motor gliders with pistons are pretty much outdated these days. This is also in your price range. Starts with the flip of a switch and flies great! |
On Aug 3, 7:13*am, Mitch wrote:
http://www.desertaerospace.com/bonusjet.html 'nuff said. *Motor gliders with pistons are pretty much outdated these days. *This is also in your price range. *Starts with the flip of a switch and flies great! Happened to be in Moriaty and got to see the engine extention and retraction. Nice piece of work. The ship does not have retractable gear but that is not much of a limitation considering the fun one would have with this thing. |
Here is another observation, and I'll try to make it as objectively as I know how. Bob Carrolton did the original flight testing of this configuration in Arkansas then brought the prototype to Moriarity. I observed his first flight with it in New Mexico, and many subsequent flights- all at density altitudes in the 10,000'- 12,000' range. To give perspective, the two place glider I was flying on those occasions would often only average a few hundred feet a minute in climb behind a Pawnee. On a couple of flights, we spent many minutes on tow under 400' and near the airport. On every occasion, the turbine powered prototype climbed robustly and very impressively. Much faster than any motorglider I have even seen. I do not think that the published climb rate of 900 fpm is an exaggeration, but this is only from my personal observation. It would be reasonable to assume that as Bob and Mark Mocho continue to refine and optimize the system, performance will improve. The implementation is elegant, simple (read that fewer problems or failures), and efficient for a turbine. The turbine which is utilized has a very long history, a continuous production run, and a solid service history. If the Test (design) glider- which is very affordable- doesn't float your boat for whatever reason, Bob can custom engineer a turbine implementation on something that likely would. I don't have any connection to this group, and only owned a motorglider for a short period of time back in the 1980's. However, I would love to have one of these turbines on something with high performance. And I think that Bob's group is doing important pioneering work in this field. Best Regards, Gary Osoba |
On Aug 3, 2:02*pm, Gary Osoba wrote:
Here is another observation, and I'll try to make it as objectively as I know how. *Bob Carrolton did the original flight testing of this configuration in Arkansas then brought the prototype to Moriarity. I observed his first flight with it in New Mexico, and many subsequent flights- all at density altitudes in the 10,000'- 12,000' range. To give perspective, the two place glider I was flying on those occasions would often only average a few hundred feet a minute in climb behind a Pawnee. On a couple of flights, we spent many minutes on tow under 400' and near the airport. On every occasion, the turbine powered prototype climbed robustly and very impressively. Much faster than any motorglider I have even seen. I do not think that the published climb rate of 900 fpm is an exaggeration, but this is only from my personal observation. It would be reasonable to assume that as Bob and Mark Mocho continue to refine and optimize the system, performance will improve. The implementation is elegant, simple (read that fewer problems or failures), and efficient for a turbine. *The turbine which is utilized has a very long history, a continuous production run, and a solid service history. If the Test (design) glider- which is very affordable- doesn't float your boat for whatever reason, Bob can custom engineer a turbine implementation on something that likely would. I don't have any connection to this group, and only owned a motorglider for a short period of time back in the 1980's. However, I would love to have one of these turbines on something with high performance. And I think that Bob's group is doing important pioneering work in this field. Best Regards, Gary Osoba It's been about 5 years now, but the last TST built glider I saw was rather crude in many ways: The wing spar was wood, no automatic hookups and there were other fit and finish issues that made me somewhat adverse to owning a glider built by these folks. Now.............don't get me wrong, if the reason they are "affordable" is because of these issues than they are moot, but if the reason is labor costs and a desire to offer an "affordable" glider is part of the company philosophy then more power to them. I have not seen the jet powered 2 seater, I hope to someday................I also hope that the company has refined their manufacturing process to put out a higher quality product. I thought the concept of the TST-10 Atlas was pretty cool. A jet powered 2 seater even cooler................and I do have an empty engine bay in my Apis-13! Brad |
On 8/3/2010 4:31 AM, TeetJ wrote:
Any suggestions for self-launch two-seater glider at 100 000 EUR range? My current list: ASH-25M: ASH25 self launchers tend to start from EUR 160 000 unfortunately. Do you know how sophisticated is the engine operation? Is there any flight manual available in the net? (my brief look at Duo Discus T engine starting procedure was quite a bad surprise, is ASH-25M the same?) DG-1001M: looks like ideal bird, but brand new and probably very expensive? ASK-21 Mi: Trainer, I would like to get better XC performance. New model and a bit expensive, too. Nimbus 4DM: Looks quite expensive and non impressive. "No aerobatics, even no intentional spins" in the documentation is not attractive at all. Janus CM: very rare species, does anybody suggest? Grob G103 Twin III SL: Also no clue how good can it be Stemme S10: quite expensive and I am not quite sure how good for thermalling it really is. More for touring. Thank you! Teet www.purilend.ee A 2 year old ad for a 40 year vold Fournier RF-5. That's my idea of a 2 seat self launch! :-) http://tinyurl.com/2fn9k5w Brian W |
The DG500M should also fit your requirements.
Late C- model Janii aren't bad, the CM should all be the improved fuselage (especially rear cockpit). I have seen a Grob Twin 3M do surprisingly well in Club Class competition. Jim |
On 8/3/2010 2:31 AM, TeetJ wrote:
Any suggestions for self-launch two-seater glider at 100 000 EUR range? My current list: Add the Taurus to your list: http://www.mcp.com.au/pipistrel-usa/models/taurus.html -- Eric Greenwell - Washington State, USA (netto to net to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl - "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz |
On Aug 4, 8:18*am, Eric Greenwell wrote:
On 8/3/2010 2:31 AM, TeetJ wrote: Any suggestions for self-launch two-seater glider at 100 000 EUR range? My current list: Add the Taurus to your list: http://www.mcp.com.au/pipistrel-usa/models/taurus.html -- Eric Greenwell - Washington State, USA (netto to net to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarmhttp://tinyurl.com/yb3xywl - "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz True, I forgot about Taurus. I was a bit scared because Taurus being UL. How good speed-gliding performance you can realistically get from relatively light glider? Does anyone have experience how this bird behaves in thermals? Thanks |
http://www.mcp.com.au/pipistrel-usa/models/taurus.html True, I forgot about Taurus. I was a bit scared because Taurus being UL. How good speed-gliding performance you can realistically get from relatively light glider? Does anyone have experience how this bird behaves in thermals? Thanks I flew in a contest last year where there was a Taurus and it seems to have performance similar to a Cirrus. That would be less than the 40:1 claimed by the factory but still very respectable. The owner is not experienced in competition flying so it would be interesting to see how it performs in the hands of a seasoned pilot. I´m pretty sure it would do very well. It´s a really beautiful ship, very well built and with one of the best engine pylon systems I´ve seen so far. The cockpit is very modern and comfortable and it also has a ballistic parachute. Bang for buck I think it´s probably one of the best deals around and I would love to have one if I could afford it. Klaus Ohlman has one and seems to be happy with it.. Regards, Juan Carlos |
| Thread Tools | |
| Display Modes | |
| F-16 Two Seater | Canuck[_2_] | Aviation Photos | 0 | September 3rd 08 04:40 PM |
| two seater BD5 | Philippe Vessaire | Home Built | 6 | October 28th 07 06:28 PM |
| WTB 2 seater L/S Nav | Sleigh | Soaring | 0 | June 11th 06 07:50 PM |
| WTB L/S Nav 2 Seater | Sleigh | Soaring | 0 | May 20th 06 09:28 PM |
| 4-seater | Nyal Williams | Soaring | 54 | November 29th 04 11:53 AM |
