Dick Johnson's wing flattening jig?
Old August 22nd 10, 05:15 PM posted to rec.aviation.soaring
Bob Kuykendall
Default Dick Johnson's wing flattening jig?
On Aug 21, 2:55 pm, ryanglover1969 wrote:
Very interesting indeed!
Blather aside, I'm thinking that the tool in question is a waviness
gauge such as the one I made for checking plugs and molds:
http://www.hpaircraft.com/hp-24/upda...october_04.htm
My experience, backed by template checks on a variety of sailplanes,
is that getting the waviness below .004" is a lot more important than
making the airfoil exactly match the intended contour.
Thanks, Bob K.
Old August 22nd 10, 05:38 PM posted to rec.aviation.soaring
T8
And after about a half hour of gauging the spar dips and bumps on
ships at your local airport, you can give the gauge to someone else
because you'll be "calibrated". A 0.006" wiggle is quite noticeable
by hand. 0.003 starts to feel pretty smooth.
-T8
Old August 22nd 10, 05:55 PM posted to rec.aviation.soaring
Brad[_2_]
because you'll be "calibrated". *A 0.006" wiggle is quite noticeable
by hand. *0.003 starts to feel pretty smooth.
-T8
when I finished the wing plugs for the HP-24 they were easily within .
003, by the time we were able to make the molds the plugs had
developed a few creases where the foam core butted together. now that
the wings are made, and I've sprayed a bunch of high-solids primer on
them, there are no wiggles or waggles anymore............after I spray
the top coat and go thru the various grades of wet paper, they should
look and feel very nice.
Brad
Old August 22nd 10, 06:12 PM posted to rec.aviation.soaring
Thanks, Bob K.
BLATHER! You call JJ's safety device blather?
Geez. It makes as much sense as a lot of what I read on here.
It's raining and I'm stuck in the shop. This is my only relief so
humor me.
My experience differs from yours. A wave free wing with the wrong
contour may , and commonly does, result in a smooth P.O.S. A lot of
ships, particularly older ones, don't have the leading edge contour
correct. This can have a larger effect on performance than waves.
And- once you put the gage, or in my case my hand, on the wing and
find a wave, how do you decide what to do about it? The obvious
answer is sand the high area off. As often as not, this is the wrong
thing to do.
Sanding wings is pretty much the last thing you do to improve
performance, after doing all the other things that are easier and less
likely to go wrong.
UH
Dick Johnson's wing flattening jig? ryanglover1969[_2_] Soaring 17 August 23rd 10 03:07 PM
Dick Johnson's wing flattening jig? ryanglover1969[_2_] Soaring 0 August 21st 10 10:55 PM
Dick Johnson Clint Soaring 4 June 6th 09 10:40 PM
Dick Johnson's FTE of the Discus-2 Flavio Formosa Soaring 1 January 18th 07 03:18 PM
Richard Johnson's Report on the Sparrowhawk skysailor Soaring 10 February 21st 05 09:47 AM
