Anybody successful in connecting a Cambridge 302 to a laptop using the
new USB port? The instructions say that the laptop should find the necessary driver on the device, mine does not, says it can not find driver software for DLP-TXRX, and that's as far as I can get. Is it possible to get the necessary driver from an outside source and put it in a place where the laptop can find it? I would really like to be able to configure the 302 from a laptop via USB since the 302 serial port is now tied up with the Oudie connection, and the Oudie will not run the PDA version of the Cambridge utility. Thanks.... NG |
On Sep 10, 4:54*pm, NG wrote:
Anybody successful in connecting a Cambridge 302 to a laptop using the new USB port? *The instructions say that the laptop should find the necessary driver on the device, mine does not, says it can not find driver software for DLP-TXRX, and that's as far as I can get. *Is it possible to get the necessary driver from an outside source and put it in a place where the laptop can find it? *I would really like to be able to configure the 302 from a laptop via USB since the 302 serial port is now tied up with the Oudie connection, and the Oudie will not run the PDA version of the Cambridge utility. * *Thanks.... NG God this whole thing is such a half-baked piece of crap. Many peopel don't get this is just a USB to serial adapter Cambridge has stuffed into the C302. Done a poor job doing that, and then done a poor job with explaining the feature, poor documentation and support. You are probalby better off using one of several commerciallty available USB to serial adopters. I like this one http://www.amazon.com/Keyspan-Speed-.../dp/B0000VYJRY $30 well spent and it comes with pretty good drivers, actual support, etc. -- Ive asked before for people to let me know the chipset the host sees in this adapter. Nobody replied. If you are a technical computer person then you may want to try the drivers at http://www.ftdichip.com/FTDrivers.htm Follow the (technical) discussion there to the right drivers for the chipset. If you are not technical computer person I would seriously suggest getting the Keyspan device above. It will help in future if you say what OS and version you running when asking for things like help with drivers. Darryl |
On Sep 10, 7:29*pm, Darryl Ramm wrote:
On Sep 10, 4:54*pm, NG wrote: Anybody successful in connecting a Cambridge 302 to a laptop using the new USB port? *The instructions say that the laptop should find the necessary driver on the device, mine does not, says it can not find driver software for DLP-TXRX, and that's as far as I can get. *Is it possible to get the necessary driver from an outside source and put it in a place where the laptop can find it? *I would really like to be able to configure the 302 from a laptop via USB since the 302 serial port is now tied up with the Oudie connection, and the Oudie will not run the PDA version of the Cambridge utility. * *Thanks.... NG God this whole thing is such a half-baked piece of crap. Many peopel don't get this is just a USB to serial adapter Cambridge has stuffed into the C302. Done a poor job doing that, and then done a poor job with explaining the feature, poor documentation and support. You are probalby better off using one of several commerciallty available USB to serial adopters. I like this onehttp://www.amazon.com/Keyspan-Speed-Serial-Adapter-USA-19HS/dp/B0000V... $30 well spent and it comes with pretty good drivers, actual support, etc. -- Ive asked before for people to let me know the chipset the host sees in this adapter. Nobody replied. If you are a technical computer person then you may want to try the drivers athttp://www.ftdichip.com/FTDrivers.htm Follow the (technical) discussion there to the right drivers for the chipset. If you are not technical computer person I would seriously suggest getting the Keyspan device above. It will help in future if you say what OS and version you running when asking for things like help with drivers. Darryl Darryl, I will let you know as soon as I get it to work. I am waiting for a Fedex package to be delivered tomorrow with the USB 302A. I was not blowing you off. I had to send my 302A back to Jeff because the 302A quit working.I tried to get the serial adapter working using your advice and some how I deleted the firmware on the 302. I am not blaming you but somehow in all my limited knowledge of trying to get the basic 302 to work with my laptop, I deleted the firmware according to Jeff. He promises that the CD and the cord will be included to make it work with any laptop. I remain cautiously optimistic. I will report everything you requested when I get it to work. Thanks for your understanding. Doug |
On Sep 10, 10:29*pm, Darryl Ramm wrote:
On Sep 10, 4:54*pm, NG wrote: Anybody successful in connecting a Cambridge 302 to a laptop using the new USB port? *The instructions say that the laptop should find the necessary driver on the device, mine does not, says it can not find driver software for DLP-TXRX, and that's as far as I can get. *Is it possible to get the necessary driver from an outside source and put it in a place where the laptop can find it? *I would really like to be able to configure the 302 from a laptop via USB since the 302 serial port is now tied up with the Oudie connection, and the Oudie will not run the PDA version of the Cambridge utility. * *Thanks.... NG God this whole thing is such a half-baked piece of crap. Many peopel don't get this is just a USB to serial adapter Cambridge has stuffed into the C302. Done a poor job doing that, and then done a poor job with explaining the feature, poor documentation and support. You are probalby better off using one of several commerciallty available USB to serial adopters. I like this onehttp://www.amazon.com/Keyspan-Speed-Serial-Adapter-USA-19HS/dp/B0000V... $30 well spent and it comes with pretty good drivers, actual support, etc. -- Ive asked before for people to let me know the chipset the host sees in this adapter. Nobody replied. If you are a technical computer person then you may want to try the drivers athttp://www.ftdichip.com/FTDrivers.htm Follow the (technical) discussion there to the right drivers for the chipset. If you are not technical computer person I would seriously suggest getting the Keyspan device above. It will help in future if you say what OS and version you running when asking for things like help with drivers. Darryl Thanks, I just ordered the serial-usb adapter and will try that. My laptop is 32-bit Vista, by the way. I also queried R-Track about the USB driver issue. Not sure how I would tell 'what chipset the host sees in this adapter'... NG |
On Sep 10, 11:35*pm, NG wrote:
On Sep 10, 10:29*pm, Darryl Ramm wrote: On Sep 10, 4:54*pm, NG wrote: Anybody successful in connecting a Cambridge 302 to a laptop using the new USB port? *The instructions say that the laptop should find the necessary driver on the device, mine does not, says it can not find driver software for DLP-TXRX, and that's as far as I can get. *Is it possible to get the necessary driver from an outside source and put it in a place where the laptop can find it? *I would really like to be able to configure the 302 from a laptop via USB since the 302 serial port is now tied up with the Oudie connection, and the Oudie will not run the PDA version of the Cambridge utility. * *Thanks.... NG God this whole thing is such a half-baked piece of crap. Many peopel don't get this is just a USB to serial adapter Cambridge has stuffed into the C302. Done a poor job doing that, and then done a poor job with explaining the feature, poor documentation and support. You are probalby better off using one of several commerciallty available USB to serial adopters. I like this onehttp://www.amazon.com/Keyspan-Speed-Serial-Adapter-USA-19HS/dp/B0000V... $30 well spent and it comes with pretty good drivers, actual support, etc. -- Ive asked before for people to let me know the chipset the host sees in this adapter. Nobody replied. If you are a technical computer person then you may want to try the drivers athttp://www.ftdichip.com/FTDrivers.htm Follow the (technical) discussion there to the right drivers for the chipset. If you are not technical computer person I would seriously suggest getting the Keyspan device above. It will help in future if you say what OS and version you running when asking for things like help with drivers. Darryl Thanks, I just ordered the serial-usb adapter and will try that. *My laptop is 32-bit Vista, by the way. *I also queried R-Track about the USB driver issue. *Not sure how I would tell 'what chipset the host sees in this adapter'... NG I hate to admit to being a Vista user (I'm a Mac guy with a Toshiba laptop to handle applications such as the C-302, Seeyou, etc.), but my Vista machine did sort out the proper driver on its own. Slowly, as I recall. the "upgrade" is a real lashup, yes. It's tempting to rant on about some other 302 oddities, but I'm going flying today. See ya! Evan Ludeman / T8 |
On Sep 10, 8:35*pm, NG wrote:
On Sep 10, 10:29*pm, Darryl Ramm wrote: On Sep 10, 4:54*pm, NG wrote: Anybody successful in connecting a Cambridge 302 to a laptop using the new USB port? *The instructions say that the laptop should find the necessary driver on the device, mine does not, says it can not find driver software for DLP-TXRX, and that's as far as I can get. *Is it possible to get the necessary driver from an outside source and put it in a place where the laptop can find it? *I would really like to be able to configure the 302 from a laptop via USB since the 302 serial port is now tied up with the Oudie connection, and the Oudie will not run the PDA version of the Cambridge utility. * *Thanks.... NG God this whole thing is such a half-baked piece of crap. Many peopel don't get this is just a USB to serial adapter Cambridge has stuffed into the C302. Done a poor job doing that, and then done a poor job with explaining the feature, poor documentation and support. You are probalby better off using one of several commerciallty available USB to serial adopters. I like this onehttp://www.amazon.com/Keyspan-Speed-Serial-Adapter-USA-19HS/dp/B0000V... $30 well spent and it comes with pretty good drivers, actual support, etc. -- Ive asked before for people to let me know the chipset the host sees in this adapter. Nobody replied. If you are a technical computer person then you may want to try the drivers athttp://www.ftdichip.com/FTDrivers.htm Follow the (technical) discussion there to the right drivers for the chipset. If you are not technical computer person I would seriously suggest getting the Keyspan device above. It will help in future if you say what OS and version you running when asking for things like help with drivers. Darryl Thanks, I just ordered the serial-usb adapter and will try that. *My laptop is 32-bit Vista, by the way. *I also queried R-Track about the USB driver issue. *Not sure how I would tell 'what chipset the host sees in this adapter'... NG You should be able to tell what USB chipset is present even if it is not working. Go to the Windows device manager and look under "Universal Serial Bus Controllers" and expand that list and double- click on what looks like the USB to serial converter (or anything else there that looks new - easy to tell by plugging and unplugging the C302 and see what appears) . Then tell me what is on the "General" and "DriverDriver Details" panels for that device. But either way it looks like it is an FTDI USB to serial converter chip (or one of their fancier chips that includes that capability) and probalby an OEM board from DLP (i.e. why the DLP-TXRX warning). I should have provided the next level link to the FTDI drivers at http://www.ftdichip.com/Drivers/VCP.htm People can always try installing the drivers from there. I've not tried, you are on your own. Advanced users can also find USB driver tools here http://www.dlpdesign.com/#Drivers Proper documentation from Cambrodge would deal with how to handle driver problems. Windows Plug and Play is always problematic and just shipping product and hoping this works is silly. Darryl |
Thanks for the many helpful suggestions. Here's where the painful path has taken me so far: Jeff at R-Track kindly provided the USB driver by email, and I installed it by hand. I also installed the similar FTDI driver recommended by Darryl. Neither worked. I did see the dancing mouse cursor issue mentioned by some in other threads. No amount of rebooting or reinstalling made a difference. The serial-to-usb adapter I ordered has a large housing for the electronics integrated with the serial plug, too large to fit onto the back of the 302. So I ordered a serial extension cable, it arrived a few days ago. Today, I finally got that hooked up, and the laptop recognized it and assigned it as port 17. I fired up the Cambridge utility, set the port to 'other' and number 17, and... nothing. I finally tried remapping the adapter port assignment to port 1 using the adapter assistant software, and set that in the Cambridge utility, and... SUCCESS! Perhaps when the Cambridge utility software was written nobody ever thought there might be so many ports available, and it's out of the undocumented usable range? So, again, thanks for the help. I agree the usb mod on the 302 is useless, but at least I can now set the aircraft type and identification (the only two things that must be done using the Cambridge utility, with no other work-around option). By the way, I also now have one of the new LX Nano flight recorders, absolutely love it, so simple to use, no connection to the glider required at all, connects effortlessly to any laptop for declarations, just turn it on and put it in your shirt pocket -- really makes the 302 seem like an antique as a recorder, though of course I still value all of the flight computer and variometer functions. NG |
| Thread Tools | |
| Display Modes | |
| For Maule Driver | Ray Lovinggood | Soaring | 18 | December 26th 05 11:36 PM |
| For Maule Driver | Ray Lovinggood | Soaring | 0 | December 1st 05 01:58 AM |
| Cambridge 302/Cambridge 3UTIQ255 utility/ WinPilot/iPAQ 4155 | Nathan Whelchel | Soaring | 4 | July 6th 04 12:22 AM |
| New Nvidia driver | Anthony Acri | Simulators | 1 | March 16th 04 08:13 PM |
| Looking to get in touch with a "Thud Driver" | Jarrod Cunningham | Military Aviation | 0 | September 6th 03 06:59 AM |
