math problem-slightly OT
Old September 14th 10, 09:32 PM posted to rec.aviation.soaring
Brad[_2_]
Default math problem-slightly OT
ok, I'm pretty math challenged....so here goes......I'm about ready to
start power cutting/buffing my HP-24 horiz stabilizer..............the
RPM range for my power buffer is 1000 to 3000 rpm. the rotary knob on
the power buffer is numbered from 1 to 6.
I am pretty sure that number 1 would be 1000 rpm and number 6 would be
3000 rpm. the rubbing compound and the polishing compounds require
specific rpm settings.............sooooooooo.........
my question is what rpm settings would I get from numbers 2 thru 5?
and don't tell me that I my Harbor Fraud power buffer is the
problem........
Brad
Old September 14th 10, 09:50 PM posted to rec.aviation.soaring
Tony[_5_]
problem........
Brad
(3000-1000)/(6-1) = 400 RPM increments, assuming that it is a linear
scale.
1 - 1000
2 - 1400
3 - 1800
4 - 2200
5 - 2600
6 - 3000
do you have one of those guns that people use to determine the RPM of
their propellers or fan blades or anything else that spins? Might be
able to get it to read the RPM of your buffer to make sure that the
knob is in fact a linear scale.
Old September 14th 10, 09:52 PM posted to rec.aviation.soaring
problem........
Brad
Turn it up till it burns gelcoat- then slow down.
That's how everybody does it.
UH
Old September 14th 10, 09:57 PM posted to rec.aviation.soaring
Brad[_2_]
problem........
Brad
scale.
1 - 1000
2 - 1400
3 - 1800
4 - 2200
5 - 2600
6 - 3000
their propellers or fan blades or anything else that spins? *Might be
thanks guys............don't have one of those rpm guns, I'll use the
400 rpm change per click and make sure I don't burn the gel-
coat...................HANK..............you know how hard I've
struggled to get a nice looking gelcoat...........BURN
IT!.................no way...........
Cheers,
Brad
Old September 14th 10, 10:11 PM posted to rec.aviation.soaring
KevinFinke
Hey Brad, I don't think Hank was implying that you burn the whole
thing, and then turn it down.
Surely you must have a test part that you could use? Maybe Dan could
loan you his cirrus horizontal for a weekend.
-Kevin
Old September 14th 10, 11:34 PM posted to rec.aviation.soaring
Dave Nadler
problem........
Brad
Mine goes up to 11.
Old September 14th 10, 11:43 PM posted to rec.aviation.soaring
Bob Kuykendall
On Sep 14, 3:34*pm, Dave Nadler wrote:
Mine goes up to 11.
Police said it was one of those cases best left unsolved!
Looking for a math wiz! Chad Speer Piloting 41 December 28th 06 10:11 AM
Looking for a math wiz! Chad Speer Instrument Flight Rules 22 December 19th 06 11:40 PM
Slightly OT Fiberglass over foam problem Dave Lyon Home Built 0 August 10th 06 03:44 PM
Help with 152 math pittss1c Piloting 12 May 13th 05 01:47 PM
Math help request ? Snead1 Soaring 5 June 8th 04 11:15 PM
