Is there an easy way to check that my solar powered vent on top of the
Cobra trailer is functioning properly? I haven't heard it running lately, but don't really know what triggers it to run (besides light of course...) Thanks, Matt |
If it's the Intersolar vent as delivered from Cobra, it's likely
"D.E.D." The 4" Nicro Day/Night vent with C-cell NiMH battery works very well. You'll just need to drill 3 new mounting holes and plug the old ones if replacing an Intersolar vent. If the battery is completely dead, the Nicro may not work. If the push-button switch inside (not everyone knows it's there) is in the OFF position, it won't do much either. The Nicro is available from most gliding suppliers or marine suppliers. Jim |
So these things are designed to run continuously? They don't kick on
when the temp is above a set point? |
On Sep 25, 10:13*pm, "Matt Herron Jr." wrote:
So these things are designed to run continuously? *They don't kick on when the temp is above a set point? Nope. They just run whenever there is power (sun or battery) available, as long as the push-button switch (which some don't have) is ON. |
On Sep 26, 8:35*am, brianDG303 wrote:
On Sep 25, 10:13*pm, "Matt Herron Jr." wrote: So these things are designed to run continuously? *They don't kick on when the temp is above a set point? Nope. They just run whenever there is power (sun or battery) available, as long as the push-button switch (which some don't have) is ON. Now, with winter coming, is a great time to hear the assembled wisdom (and random opinions!) of r.a.s. on the trailer vent issue. It's been nagging me for years. Most trailers are left outside. Go look at your glider at 6 am. It's covered with condensation. Bad. The sun comes out, the condensation dries, and the vent sucks it all out. Well, that's better than no vent, in which case it would stay dripping all day and the gel coat would peel off in your hands after a few months. I bought a little recording hygrometer to test all this, and the result is frightening -- 100% relative humidity for the early morning hours. So, I got a battery powered vent that sucks all night too. But am I doing any good? I'm just sucking in more humid air. I stack the thing with drying crystals, but who knows if that is helping. Sure, they soak up a lot of moisture, but since I'm also venting perhaps they are just drying air that I then promptly pump outside. The right answer is to hook it up to power and throw in a dehumidifier. This works like a charm... but there is no power at my trailer. A small heater works well too, and I use one over the winter. But there is no power at my trailer. An even better answer of course is to store it inside in a humidity controlled environment. Note: The average hangar can be worse than outside. They leak, the solar vent no longer works, and that huge concrete slab below you is a humidity magnet in the springtime; it also keeps the glider from warming up and drying out. Sooo. Does anyone have hard data or anything other than obvious opinions on what works best? Vents were solution 1.0 to this problem. Are battery powered vents better or worse? What's solution 2.0? Some solar powered heating or dehumidifier system seems to be the way to go, but it has to cost less than a hangar. John Cochrane |
On Sep 26, 11:42*am, John Cochrane
wrote: On Sep 26, 8:35*am, brianDG303 wrote: On Sep 25, 10:13*pm, "Matt Herron Jr." wrote: So these things are designed to run continuously? *They don't kick on when the temp is above a set point? Nope. They just run whenever there is power (sun or battery) available, as long as the push-button switch (which some don't have) is ON. Now, with winter coming, is a great time to hear the assembled wisdom (and random opinions!) of r.a.s. on the trailer vent issue. It's been nagging me for years. Most trailers are left outside. Go look at your glider at 6 am. It's covered with condensation. Bad. The sun comes out, the condensation dries, and the vent sucks it all out. Well, that's better than no vent, in which case it would stay dripping all day and the gel coat would peel off in your hands after a few months. I bought a little recording hygrometer to test all this, and the result is frightening -- 100% relative humidity for the early morning hours. So, I got a battery powered vent that sucks all night too. But am I doing any good? I'm just sucking in more humid air. I stack the thing with drying crystals, but who knows if that is helping. Sure, they soak up a lot of moisture, but since I'm also venting perhaps they are just drying air that I then promptly pump outside. The right answer is to hook it up to power and throw in a dehumidifier. This works like a charm... but there is no power at my trailer. A small heater works well too, and I use one over the winter. But there is no power at my trailer. An even better answer of course is to store it inside in a humidity controlled environment. Note: The average hangar can be worse than outside. They leak, the solar vent no longer works, and that huge concrete slab below you is a humidity magnet in the springtime; it also keeps the glider from warming up and drying out. Sooo. Does anyone have hard data or anything other than obvious opinions on what works best? *Vents were solution 1.0 to this problem. Are battery powered vents better or worse? What's solution 2.0? Some solar powered heating or dehumidifier system seems to be the way to go, but it has to cost less than a hangar. John Cochrane The opinion we have at our airport (and that's all it is, I'm afraid), is that the purely solar powered vents are best. When the weather is warm and dry and sunny they pull air through your trailer and dry it out. When the weather is damp and cloudy they leave well enough alone. My plane sat parked in its trailer for 6 years before I bought it. It didn't have a solar vent. The condensation would collect on the wings and fuselage, run down to the low point (leading edge of the wings), and gradually rot the gelcoat. It had to have a partial refinish of the leading edges before I bought it. I got a solar vent and installed it early this year to improve the circulation. In my case the passive vents were in the front of the trailer, so I put mine on top of the doghouse. -- Matt |
Could someone please explain the condensation cycle inside a trailer?
I understand that, at night, the relative humidity increases all around. I assume that the air inside the trailer cools slower than the air outside, as thus, becomes warmer relative to the outside. Does the relatively warm air inside the trailer then condensate against the cold inner skin of the trailer? Is it then fair to assume that the water we find on the glider is the result of the condensation dripping on the glider, and not air condensating on the glider itself? Thanks. |
On Sep 26, 1:11*pm, Bastoune wrote:
Could someone please explain the condensation cycle inside a trailer? I understand that, at night, the relative humidity increases all around. I assume that the air inside the trailer cools slower than the air outside, as thus, becomes warmer relative to the outside. Does the relatively warm air inside the trailer then condensate against the cold inner skin of the trailer? Is it then fair to assume that the water we find on the glider is the result of the condensation dripping on the glider, and not air condensating on the glider itself? Thanks. And once the morning warming cycle starts and the surfaces of the trailer warm up before the high thermal mass parts of the glider the water may cycle back in the air and condense on the glider. Open some damp trailers in the early morning and you'll see condensation clearly on the glider. Once the glider surfaces fall below the dew point moisture could also condense there, so its not exclusively going to be on the outer surfaces. I also would like to see some study of humidity in trailers, all the folklore and different ideas about fiberglass or aluminum top trailers, insulated trailer tops, different types of vents and fans etc. would be interesting to explore. I started to build a data logger that could capture the humidity and air and surface temps but got sidetracked and never got it finished. I am concerned that some of the fans may such in moist air in the morning that condenses and then takes a while to vent out. Maybe by the time the solar fans really kick in the glider has warmed enough, but who knows. The very worst thing probably just a leak either of rain or condensation on the outside of the trailer. Worth double checking that any water on the floor of the trailer is not simply from a leak. I've had both my cobra aluminum top trailers one brand new, one near new) leak rainwater around the tail fin vent and was a simple matter of removing and reinstalling with fresh silicone sealant. Worth playing with a hose and checking out if they leak. Darryl |
On Sep 26, 8:42*am, John Cochrane
wrote: On Sep 26, 8:35*am, brianDG303 wrote: On Sep 25, 10:13*pm, "Matt Herron Jr." wrote: So these things are designed to run continuously? *They don't kick on when the temp is above a set point? Nope. They just run whenever there is power (sun or battery) available, as long as the push-button switch (which some don't have) is ON. Now, with winter coming, is a great time to hear the assembled wisdom (and random opinions!) of r.a.s. on the trailer vent issue. It's been nagging me for years. Most trailers are left outside. Go look at your glider at 6 am. It's covered with condensation. Bad. The sun comes out, the condensation dries, and the vent sucks it all out. Well, that's better than no vent, in which case it would stay dripping all day and the gel coat would peel off in your hands after a few months. I bought a little recording hygrometer to test all this, and the result is frightening -- 100% relative humidity for the early morning hours. So, I got a battery powered vent that sucks all night too. But am I doing any good? I'm just sucking in more humid air. I stack the thing with drying crystals, but who knows if that is helping. Sure, they soak up a lot of moisture, but since I'm also venting perhaps they are just drying air that I then promptly pump outside. The right answer is to hook it up to power and throw in a dehumidifier. This works like a charm... but there is no power at my trailer. A small heater works well too, and I use one over the winter. But there is no power at my trailer. An even better answer of course is to store it inside in a humidity controlled environment. Note: The average hangar can be worse than outside. They leak, the solar vent no longer works, and that huge concrete slab below you is a humidity magnet in the springtime; it also keeps the glider from warming up and drying out. Sooo. Does anyone have hard data or anything other than obvious opinions on what works best? *Vents were solution 1.0 to this problem. Are battery powered vents better or worse? What's solution 2.0? Some solar powered heating or dehumidifier system seems to be the way to go, but it has to cost less than a hangar. John Cochrane You could buy about 100 of these: http://tinyurl.com/254daal If your trailer is well sealed maybe you won't have to dry them out on a regular basis. I think traditional dehumidifiers draw 3-5 amps - too much for solar or battery. 9B |
On Sep 25, 10:17*pm, "Matt Herron Jr." wrote:
Is there an easy way to check that my solar powered vent on top of the Cobra trailer is functioning properly? *I haven't heard it running lately, but don't really know what triggers it to run (besides light of course...) Thanks, Matt Lie down next to the fuselage. Have your significant other close, latch, and lock the trailer. After a couple of days in there you should have a pretty good idea of how its working. See ya, Dave |
| Thread Tools | |
| Display Modes | |
| COBRA TRAILER | Gordon Schubert[_2_] | Soaring | 0 | February 10th 09 05:15 AM |
| Cobra Trailer | [email protected] | Soaring | 22 | December 8th 06 12:38 AM |
| Solar vents delivered on Cobra trailers | Dan Dunkel | Soaring | 7 | April 4th 04 09:38 PM |
| Cobra Trailer | Soaring | 1 | September 28th 03 02:14 PM | |
| FS: Cobra Trailer | Ed Byars | Soaring | 0 | September 22nd 03 05:47 PM |
