Mode S code?
Old July 16th 04, 03:22 PM
William W. Plummer
Default Mode S code?
I was looking at the FAA N-number database. Everything seems to have a
mode S code, even a friend's balloon that doesn't have a transponder.
Can anybody explain that?
Old July 16th 04, 03:51 PM
On Fri, 16 Jul 2004 13:22:56 GMT, "William W. Plummer"
It's probably easier to assign a code to *everything* that has an N-number.
After all, the FAA may eventually require all aircraft to carry a
transponder. Plus, if your friend's balloon is eventually decommissioned
and the N-number reassigned, the Mode S code is already established.
Old July 16th 04, 04:07 PM
G. Burkhart
"Ron Wanttaja" wrote in message
N-number.
I may be wrong, but isn't the S code unique for an aircraft? If an aircraft
changes its N number, does the S code change too? If an N number is
reassigned to another aircraft does the S code change?
-Greg /X
S code: 53171652
Old July 16th 04, 05:32 PM
William W. Plummer
N-number.
My guess is the S code is unique to the transponder, not the plane.
Old July 16th 04, 06:03 PM
Thomas Borchert
William,
Actually, the S code is programmed into the transponder in setup mode
and can be changed any time. The code is issued by the aviation
authorities for an aircraft registration number. Or, in the case of
airline flights, the actual flight number is programmed into the
transponder, which, as you can imagine, changes quite a bit.
With our German GTX330 installation, the LBA (German FAA-equivalent)
issued a hex code upon installation for our aircraft which was then put
into the transponder.
Thomas Borchert (EDDH)
Old July 16th 04, 08:43 PM
Ron Natalie
"William W. Plummer" wrote in message news:cxSJc.104956 I may be wrong, but isn't the S code
The Mode S goes with the aircraft. Each aircraft registration has a mode S. It's
constant whether the N number changes or what transponder is in the aircraft.
Old July 17th 04, 02:19 PM
Thomas Borchert
Ron,
What's the difference between N number and aircraft registration in
the above quote?
Old July 21st 04, 12:00 AM
Ron Natalie
"Thomas Borchert" wrote in message ...
Ron,
the above quote?
You can change the N number. The Mode S is tied to the aircraft itself (the
model and serial #).
Old July 21st 04, 01:03 AM
William W. Plummer
Ron,
the above quote?
So the Mode S number bound to the airframe. Is that the Airworthiness
Certificate? It's all sort of strange because you can replace your
transponder, a wing, radios, fuel tanks, the engine... just what is the
"aircraft"? One view is that it is the file card-size plate that
identifies the aircraft. But I thought that has the N-number on it.
Let me guess: the aircraft is the same as the N-number and that cannot
be changed. The Mode-S number is simply a reflection of the N-number.
Removing the transponder from a plane probably requires the technician
to zero the Mode-S number in the transponder. Installing a transponder
requires the tech to lookup the Mode-S number based on the N-number
Old July 21st 04, 03:56 AM
Dave Stadt
news:3xhLc.132243$IQ4.127452@attbi_s02...
Ron,
the above quote?
(the
The dataplate is the airplane. All the rest is just part numbers. A tail
number can be and often is changed and is not tied to a specific serial
number/data plate. The data plate does not have the N number engraved on
it.
Non-radar transponder codes Michael Instrument Flight Rules 16 February 13th 04 02:15 PM
Transponder code switching Ken Pruchnick Instrument Flight Rules 30 October 12th 03 09:31 PM
USAF = US Amphetamine Fools RT Military Aviation 104 September 25th 03 04:17 PM
"New" ASCC code names Andreas Parsch Military Aviation 0 September 9th 03 09:04 AM
Mode S questoin JerryK Instrument Flight Rules 1 July 17th 03 10:56 PM
