Vne/Va/Aircraft Mods
Old August 25th 04, 06:40 PM
Dale
Default Vne/Va/Aircraft Mods
I'm flying a pair of Cessna P206s that have the Wing X STOL extended
wings. This mod adds about 18 inches to each wing at the tip. (And for
anyone thinking of STOL mods I highly recommend these..they reduce
takeoff roll 20-30%).
One mandate from the STC is that Vne is lowered to 189 MPH from the
usual 210 MPH. There is no change in Va however. I'm wondering why the
reduction in Vne? If it is a load factor issue why isn't Va also
lowered?
Dale L. Falk
There is nothing - absolutely nothing - half so much worth doing
as simply messing around with airplanes.
http://home.gci.net/~sncdfalk/flying.html
Old August 26th 04, 02:16 AM
Gerry Caron
"Dale" wrote in message
lowered?
My guess is load factor is probably not the limiting factor, dynamic
pressure (Q) is. Above 189 mph, the sum of lift and drag is likely
approaching the structural limit of the extension. Whereas, at Va, the max
load factor can't generate enough Q to break the extensions.
Gerry
Old August 26th 04, 03:07 AM
john smith
That is the way it was described in a paper I downloaded last week.
O-235 Lycoming Mods Do B Home Built 2 March 19th 04 03:42 PM
clever amateur built placard mods Joa Home Built 5 January 8th 04 09:10 AM
Scaled Composites X-Prize vehicle flying again after mods David O Home Built 0 October 26th 03 06:47 AM
