Mandatory ELT specification (N-reg aircraft, 1400kg)
Old December 23rd 04, 04:10 PM
Jürgen Exner
Default Mandatory ELT specification (N-reg aircraft, 1400kg)
Peter wrote:
I am moving a plane from G-reg to N-reg and everybody in the avionics
business tells me I need a tri-band ELT like the Kannad 406 AP
http://www.adamsdirect.co.uk/proddet...delno=406%20AP
at about $3000. However I don't think this is true. What is the actual
minimum requirement?
That's pretty easy to find out, just check the FAR: 91.207 Emergency
Location Transmitters:
http://www.airweb.faa.gov/Regulatory...0?OpenDocument
Most flying here in the UK is over relatively inhabited land, or over
the sea, and I already carry a 121.5/406MHz EPIRB so don't need
anything too fancy - it just needs to comply. The most likely scenario
is ditching and a fixed unit will just sink.
Is your EPIRB approved as an ELT by the FAA?
jue
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 40 October 3rd 08 03:13 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 1st 04 02:31 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 03:04 PM
