windows 7, OLC and Cambridge
Old October 18th 10, 04:36 PM posted to rec.aviation.soaring
Howard Banks
Default windows 7, OLC and Cambridge
I am having a problem using the OLC convertor program that is supposed to
convert Cambridge files to a standard acceptable to OLC. It worked fine
on my now-dead XP laptop, but won't do anything on my new W7 machine.
Any suggestions?
HL
Old October 18th 10, 04:52 PM posted to rec.aviation.soaring
Darryl Ramm
convert Cambridge files to a standard acceptable to OLC. *It worked fine
Any suggestions?
HL
Yes. Search for this past topic on r.a.s.
Darryl
Old October 18th 10, 05:57 PM posted to rec.aviation.soaring
Greg Arnold[_2_]
Any suggestions?
HL
Open the CAI file in SeeYou, then save it as an IGC file. Then use OLC
Direct Claim to upload the saved IGC file.
Old October 18th 10, 09:26 PM posted to rec.aviation.soaring
Paul Remde
Hi Greg,
Are you certain that works? I wouldn't think it would. I thought the .igc
file was only attached when SeeYou was used to upload to the OLC.
It is my understanding that the best solution is to open the .cai file in
either SeeYou or StrePla and then use them to upload directly to the OLC
from within SeeYou or StrePla. They automatically create and attach a
(non-secure) .igc file to the secure .cai file before uploading to the OLC.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
"Greg Arnold" wrote in message
Any suggestions?
HL
Old October 18th 10, 09:44 PM posted to rec.aviation.soaring
Greg Arnold[_2_]
On 10/18/2010 1:26 PM, Paul Remde wrote:
Hi Greg,
Yep, I upload all flights for a friend who has an old CAI logger. Works
perfectly.
.igc file was only attached when SeeYou was used to upload to the OLC.
in either SeeYou or StrePla and then use them to upload directly to the
OLC from within SeeYou or StrePla. They automatically create and attach
a (non-secure) .igc file to the secure .cai file before uploading to the
OLC.
I tried that a few years ago. I may be misremembering, but I thought it
didn't work.
Best Regards,
Paul Remde
supposed to
Any suggestions?
HL
Old October 18th 10, 11:33 PM posted to rec.aviation.soaring
Rick Fuller[_2_]
Hi Greg,
Yep, I upload all flights for a friend who has an old CAI logger. *Works
perfectly.
OLC.
I tried that a few years ago. *I may be misremembering, but I thought it
didn't work.
Best Regards,
Paul Remde
supposed to
Any suggestions?
HL
Direct Claim to upload the saved IGC file.- Hide quoted text -
- Show quoted text -
For me StrePla does not open.CAI files (Flight Tracks / Import) and
cai2igc4olc doesn't convert .CAI files in Windows 7. I've tried both
in the Compatability Mode using Windows XP (Sp2). Am I out of luck or
is there a better idea out there somwhere.
Rick "CL"
Old October 18th 10, 11:52 PM posted to rec.aviation.soaring
Darryl Ramm
[snip]
I suspect this will not won't work for OLC League flights or OLC
motorglider or anything else requiring the IGC file to have intact
security, obvious badges etc. get included there as well.
Darryl
Old October 19th 10, 12:00 AM posted to rec.aviation.soaring
Darryl Ramm
Hi Greg,
perfectly.
.igc file was only attached when SeeYou was used to upload to the OLC..
OLC.
didn't work.
Best Regards,
Paul Remde
supposed to
Any suggestions?
HL
cai2igc4olc doesn't convert .CAI files in Windows 7. *I've tried both
in the Compatability Mode using Windows XP (Sp2). *Am I out of luck or
Rick "CL"
You are posting from Google Groups. Go to the search box above where
you are reading this and type in "Windows 7" to see ways to solve
this.
Windows 7 Windows XP mode may be an option - try Googling "Windows XP
Mode". Another option is dosbox. Unless you need all the baggage of
Windows XP I'd try dosbox first. See the past threads.
Darryl
WTB: 57mm Cambridge Vario/FS: 80mm Cambridge Vario ufmechanic Soaring 0 March 24th 09 05:31 PM
Cambridge 302 & PDA -- Value of adding Cambridge 303? V1 Soaring 5 July 31st 07 03:51 AM
FS: Cambridge GPS 25 [email protected] Soaring 0 October 24th 06 01:27 AM
FS Cambridge L-Nav and GPS - Nav Discus 44 Soaring 3 August 2nd 06 08:38 PM
Cambridge 302/Cambridge 3UTIQ255 utility/ WinPilot/iPAQ 4155 Nathan Whelchel Soaring 4 July 5th 04 11:22 PM
