Commercial Rating for Towing Gliders not needed? in US
Old October 31st 10, 05:58 PM posted to rec.aviation.soaring
chris
Default Commercial Rating for Towing Gliders not needed? in US
Some of the recent contests I've attended in the US had trouble
getting tow pilots and enough towplanes. One issue was the
controversial issue of do towpilots need commercial ratings to tow at
a contest.
I did just read an article that I wanted to share. I'm a bit behind on
my reading but the Feb 2010 issue of AOPA Pilot had a relevant
article. Page 42, Pilot Counsel, by John S. Yodice, AOPA general
counsel. "Complex private priviledges".
It discusses FAR 61.113.
"...the general part of the rule, a private pilot may not act as pilot
in command of an aircraft that is carrying passengers or property for
compensation or hire"...
The six exceptions to the rule are 1) a flight incidental to a
business or employment; 2) a shared expense flight; 3) a charitable
flight; 4) search and location operations; 5) sales demonstration; and
6) glider and ultralight towing.
So does that last bit mean we can have contest towpilots using their
private ticket?
I don't know how this issues was resolved otherwise but thought this
exception might have been overlooked by some contest organizers.
Also I don't know what the insurance companies require.
Chris
Old October 31st 10, 06:09 PM posted to rec.aviation.soaring
glidergeek
So does that last bit mean we can have contest tow pilots using their
private ticket?
I believe the SSA is a non profit org. But I do believe they have to
contract tow plane owners.
Unless the tow plane owner is donating there plane's services it may
not qualify.
A group or club may be a different deal as long as the pilot or club/
group isn't being comped.
Old October 31st 10, 08:53 PM posted to rec.aviation.soaring
T[_2_]
private ticket?
not qualify.
In the US, a Private rated pilot can tow gliders. He cannot receive
compensation.
A private rated tow pilot can tow for club or commercial operations,
the tow pilot cannot be compensated.
Mostly, who can tow, is run by the insurance companies.
Most may require the tow pilot to be commercially rated for a
commercial "ride for hire" glider tow. That is between the insurance
company and the commercially run glider company. This is above the FAA
14CFR requirements.
The insurance company that "insures the event" for a contest may
require the tow pilots to be commercially rated. This is above the FAA
14CFR requirements and is between the insurance company and the
contest event organizers.
Old November 1st 10, 02:54 AM posted to rec.aviation.soaring
Pete Brown
compensation.
It's not clear to me what basis you have for saying this. I would
caution you not to read in what is not there.
The pertinent parts of FAR 61.113 are shown immediately below and
explicitly permit a private pilot to tow for hire or compensation. RTFR!
Paragraph FAR 61.113 (a) spells out the general prohibitions against
compensation and then paragraphs b through g spell out the exceptions to
the general prohibition.
Sec. 61.113
Private pilot privileges and limitations: Pilot in command.
(a) Except as provided in paragraphs (b) through (g) of this section, no
person who holds a private pilot certificate may act as pilot in command
of an aircraft that is carrying passengers or property for compensation
or hire; nor may that person, for compensation or hire, act as pilot in
command of an aircraft.
(non relevant parts deleted.)
[(g) A private pilot who meets the requirements of Sec. 61.69 may act as
pilot in command of an aircraft towing a glider or unpowered ultralight
vehicle.]
Amdt. 61-110, Eff. 9/1/2004
This is correct. Many insurance companies have higher requirements than
the FAA for towing generally and during contests as well.
Pete Brown
Anchorage Alaska
Going home after a long day
http://farm2.static.flickr.com/1415/...22928754_b.jpg
The fleet at Summit. Mt. McKinley is about 45nm away at 20,320 msl.
http://farm1.static.flickr.com/187/4...cb8d2482_b.jpg
The 170B at Bold near Eklutna Glacier
http://farm1.static.flickr.com/168/4...a216d7bb75.jpg
Old November 1st 10, 04:21 AM posted to rec.aviation.soaring
Brad[_2_]
compensation.
explicitly *permit a private *pilot to tow for hire or compensation. RTFR!
Sec. 61.113
vehicle.]
Pete Brown
Anchorage Alaska
Going home after a long dayhttp://farm2.static.flickr.com/1415/1325102827_f322928754_b.jpg
The fleet at Summit. Mt. McKinley is about 45nm away at 20,320 msl.http://farm1.static.flickr.com/187/4...cb8d2482_b.jpg
The 170B at Bold near Eklutna Glacierhttp://farm1.static.flickr.com/168/437324742_a216d7bb75.jpg
I'm curious about non-profit clubs that provide towing to commercial
glider operators. The CFIG/Commercial pilot is a club member, using
club towplane and resources, and charging for lessons and commercial
rides. I just don't want to see our club be on the hook if something
happens while he is on tow.
Brad
Old November 1st 10, 03:19 PM posted to rec.aviation.soaring
Frank Whiteley
compensation.
explicitly *permit a private *pilot to tow for hire or compensation.. RTFR!
Sec. 61.113
vehicle.]
Pete Brown
Anchorage Alaska
Brad
Our club currently has tow for hire insurance. If we sell a ride to
the public (allowed under the SSA group plan), the tow pilot and ride
pilot are current commercial or better and the tow plane and ride
glider is within current 100-hour checks. Neither I nor Costello will
attempt to interpret the FARs for you. Some other operations may do
things differently. As group plan policies are renewed, there are
some changes in who may be towed without tow for hire coverage, but
current SSA members of other chapters may be eligible.
In at least one SSA region, there are no commercial operations. Thus
the only options for glider rides are with clubs/chapters. I know of
one ride operator in another region that makes as much from glider
rides as his Stearman rides, therefore continues the glider ride
service. Doesn't hurt that the glider can fly over the nearby
national park and the Stearman can't. Otherwise, he's not really into
gliders. In other cases, commercial operators primary revenue streams
are rides and training. In a few cases, private owners are treated as
secondary and tows may be delayed if rides and lessons are in the
launch queue. Word gets around.
So, are rides important? Definitely in some cases they are bread and
butter services for commercial operators. Why would clubs/chapters
want to sell rides to the public? Member growth? Revenue stream?
Community relations? I would suggest there is a better way than rides
to grow your club. Introductory memberships and lessons create an
opportunity for the prospective member to see if they are a good fit
for soaring and your club. Giving rides for revenue means your club/
chapter has excess capacity (needs to grow) or members are being under
served. Resources, gliders and staff, are being directed away from
the members, the club/chapter bread and butter revenue stream. Unless
ride pilots are really developing the skills to become instructors,
giving rides as a revenue stream requires the extended costs of 100-
hour checks and perhaps insurance. If the club/chapter has an IRS tax
exempt determination, it may not compete with a commercial operator
for public revenue at the same location. If a 501c(7), then there are
also gross receipts limitations. These do not apply to members.
As long as the club doesn't charge for community relations rides,
there's no issue. Standard warnings apply.
Frank Whiteley
Old November 1st 10, 03:51 PM posted to rec.aviation.soaring
Frank Whiteley
compensation.
Sec. 61.113
vehicle.]
Pete Brown
Anchorage Alaska
Brad
Now about your more specific question.
My club's instructors are treated as independent contractors. They
charge or not and negotiate the fees with their students. A
commercial tow pilot is not required for member tows. For public
rides, a commercial tow pilot is used. The majority of our tow pilots
hold commercial ratings. That's our approach. Other clubs take other
approaches.
The question is the standards the courts will apply to involved
parties if there's an accident. When people give money for a service,
there is an expectation that the higher commercial standard is in
effect and that's what the courts will find. Does that extend to the
tow plane? I've heard both arguments. What it boils down to is the
exposure to the members of the club. It's the board's responsibility
to explain that to the members and the decision should probably not be
made solely by the board. The board should have a chat with Costello,
if under the SSA group plan.
Frank Whiteley
Old November 2nd 10, 12:45 AM posted to rec.aviation.soaring
T[_2_]
compensation.
Sec. 61.113
vehicle.]
As you quoted "except as provided" an in sub paragraph [g] .. it says
he can act as Pilot in Command to tow a glider.
It does not say he can be compensated.
T
Old November 2nd 10, 02:00 AM posted to rec.aviation.soaring
Tony[_5_]
compensation.
Sec. 61.113
vehicle.]
T
(a) says that unless a private pilot meets one of the exceptions, they
cannot be compensated. Which is to say if you are operating under one
of the exceptions, you can be compensated.
Old November 1st 10, 04:49 PM posted to rec.aviation.soaring
getting tow pilots and enough towplanes. *One issue was the
a contest.
article. *Page 42, Pilot Counsel, by John S. Yodice, AOPA general
counsel. *"Complex private priviledges".
private ticket?
Chris
I specifically got my commercial single engine land so that I could
fly for free towing gliders for a commercial operator in the
operator's tow plane. No compensation to me. Later at our club
operation a couple of tow pilots were only private-rated even though
the club was charging members and guests for tows. Seems clear that a
friend towing up their buddy at no charge or gas only, such as as two
residents at a private strip not offering service to the public, could
be private rated. Seems to me that if a tow pilot is getting any
compensation for towing in their own aircraft or someone else's beyond
pro-rata gas money it is a commercial flight. That is my opinion based
on all the restrictive rulings I have seen on sharing expenses on
power flights and that even consider free use of an airplane to build
time as compensation. Private-rated pilots have been towing gliders
for a long time, but if there is an accident the private-rated tow
pilot may be in trouble. Not sure anybody really wants a definitive
FAA ruling. In my opinion, getting a commercial rating is not really
too hard if you are serious about doing tows.
Stuart
Commercial vs Private, towing 150flivver Soaring 7 March 22nd 09 04:11 PM
Auto Towing 2 Place Gliders [email protected] Soaring 11 April 21st 06 05:10 AM
Commercial rating? Paul Tomblin Piloting 43 March 10th 06 12:19 AM
US FAR 61.113 Private Pilots Towing gliders for compensation. Jackal Soaring 21 January 23rd 05 04:37 PM
rotorcraft commercial rating or better rating advice Rick Cook Rotorcraft 0 October 13th 03 04:49 PM
