Komet Trailer ramp Lever Jack
Old November 2nd 10, 02:38 PM posted to rec.aviation.soaring
Grider Pirate
Default Komet Trailer ramp Lever Jack
A while back, I made a lever-type ramp jack for my Komet trailer.
Simple, CHEAP (my middle name) and robust. Then I had a landout on a
soft surface, and it was quite difficult to raise the glider. As a
result, I designed (LOL) the MKII jack, incorporating a large aluminum
plate for the wheels to ride on. I linked it to the ramp with a
swingarm so it would stay aligned. After building two of these rigs
(for others), I've decided that for the .1% of the time I rig (or de-
rig) on soft surfaces, I'll just carry a square of plywood.
Just the same.... http://www.youtube.com/watch?v=0abKXYtBlu8
Old November 2nd 10, 03:20 PM posted to rec.aviation.soaring
bildan
Simple, CHEAP (my middle name) and robust. *Then I had a landout on a
soft surface, and it was quite difficult to raise the glider. *As a
Just the same....http://www.youtube.com/watch?v=0abKXYtBlu8
Clever!
I've been using a jackable fuselage dolly on an ASK-21 which uses a
similar lever - it's a joy to use. The 2-place ASK-21 is heavier and
the lever is shorter yet it still works easily.
Old November 2nd 10, 04:22 PM posted to rec.aviation.soaring
Tim Taylor
I think the new one is great, but I agree that it is easier to just
keep a plywood pad in the front of the trailer. I built mine for my
old Ventus with four wheels to give a little better capability on soft
ground following your original design:
http://picasaweb.google.com/TTaylor07/TrailerJack#
Old November 2nd 10, 04:24 PM posted to rec.aviation.soaring
Tony[_5_]
I've been occasionally thinking about the best way to set up a
fuselage dolly for a fixed gear glider. All I can say after seeing
your video is "DUH!"
Old November 2nd 10, 04:46 PM posted to rec.aviation.soaring
Tim Taylor
fuselage dolly for a fixed gear glider. *All I can say after seeing
Tony,
For a fixed gear glider there is a dollie with the lever system built
into the dollie so that the wheel would be high enough to go into the
trailer. The height of the whole dollie adjusts with the over cam arm
movement. I don't have the link here but will try to find it.
Old November 2nd 10, 05:18 PM posted to rec.aviation.soaring
Tony[_5_]
Tony,
trailer. *The height of the whole dollie adjusts with the over cam arm
movement. *I don't have the link here but will try to find it.
right, after seeing you guys' setups the same sort of idea popped into
mind.
Old November 3rd 10, 02:28 PM posted to rec.aviation.soaring
Morgan[_2_]
Tony,
Here are some pictures of a very nice cradle setup for a fixed gear
glider.
http://picasaweb.google.com/morhall/GliderCradle#
Morgan
Old November 2nd 10, 05:25 PM posted to rec.aviation.soaring
n7ly
Tony - this looks a lot like mine. Been using it for a long time.
Another advantage is that I don't have to bend over to raise the
plane, just step on the handle. On soft ground you can have an added
advantage - with a plywood ramp shaped like a T. The top of the T has
enough foot print for the rollers, while the long part of the T is
long enough to roll the gear onto. It helps get the wheel out of the
mud. Trailer is at Sunflower. Dennis
Old November 2nd 10, 05:45 PM posted to rec.aviation.soaring
SoaringXCellence
advantage - with a plywood ramp shaped like a T. *The top of the T has
mud. *Trailer is at Sunflower. * *Dennis
I just sold my Grob 103 setup with a fuselage jack that worked in a
similar way but also locked to the aircraft for loading onto the
trailer. Check with Coastal Soaring for pictures if you want to
build one.
Old November 2nd 10, 08:18 PM posted to rec.aviation.soaring
bildan
trailer. *Check with Coastal Soaring for *pictures if you want to
build one.
Consider this an extension of the ramp idea.
If a fuselage in a jackable dolly can be rolled completely off the
ramp and about 15 feet away from the tailgate, maneuvering the wing
roots off the trailer is much easier - especially if the ramp is
removed once it is not needed.
If a one-man dolly is to be used, it can be placed ahead of the nose
so the wing root can be swung across in front of the nose and then
walked to the fuselage without the past-the-tail do-si-do otherwise
required. This minimizes wing dolly rolling on rough ground.
Trailer Ramp Jack - NO SCREWS - follow up Tim Taylor Soaring 13 July 17th 12 10:26 PM
WTB: Cobra Trailer Ramp Jack - US Gary Emerson Soaring 1 June 21st 09 01:34 AM
Komet Trailer Ramp Jack - NO SCREWS [email protected] Soaring 7 April 23rd 08 05:39 AM
Ramp jack for Komet Trailer [email protected] Soaring 8 April 2nd 08 05:37 PM
Double scissor jack for trailer ramp? Bullwinkle Soaring 15 January 18th 06 05:18 PM
