Glide Ratio of a King Air?
Old November 15th 10, 06:41 PM posted to rec.aviation.soaring
Karen
Default Glide Ratio of a King Air?
See:http://www.greenvilleonline.com/arti...EWS/311150009/
Pilot-says-plane-became-glider-after-it-ran-out-of-gas
Greenville last Monday. Wings look pretty skinny.Engines look real
big.
He credits his glider training. Why not require glider ratings for
every ATP?
Karen
Old November 15th 10, 07:02 PM posted to rec.aviation.soaring
Darryl Ramm
Recurrent training with some focus on boring things like pre-flight
inspections, fuel management, and in this case some reviews of flight
line operations procedures would probably be more worthwhile.
Darryl
big.
every ATP?
Karen
Old November 15th 10, 08:12 PM posted to rec.aviation.soaring
mike martin
big.
every ATP?
Karen
I wasn't there, but unless something truly abnormal happened to the
airplane, it's a pretty safe bet that poor planning and bad decision
making led to this incident. It is this same thought process you read
about in many of the glider accidents. Poor planning, poor decision
making, and poor saftey management resulting in a wrecked glider. The
best training and skill set will not overcome bad mental habits.
Old November 15th 10, 08:29 PM posted to rec.aviation.soaring
20flyer
Other than the obvious poor planning....
A King Air has a pretty decent L/D once the props are feathered.
Don't
feather and it does come down, like right now. Depending on the
model,
L/D of King Air series can be anywhere from 13/1 up to about 17/1.
We could feather both on a KA90 (engines can still be running with
feathered props), slow to best L/D speed of around 110 knots, and the
sink would settle around 800fpm. Drop gear and approach flaps and
sink
would go to about 12-1300fpm. If you unfeathered the props then,
sink
could increase 4-5000 fpm, kind of like a 20 with full flaps and
spoilers...
The longer wing 200 series was actually better than a 90....
Ah, the old days....
Steve
Does glide ratio change with altitude? Andrew Sarangan Piloting 0 September 25th 07 05:58 AM
trivia: highest glide ratio [email protected] Soaring 10 August 4th 06 10:47 PM
So you think you have a low glide ratio! COLIN LAMB Soaring 30 January 12th 06 03:47 PM
GPS glide ratio calculations james Soaring 0 May 4th 04 10:00 PM
GPS glide ratio calculations Jason Armistead Soaring 16 September 12th 03 05:50 AM
