Komet trailer interior floor refinish
Old November 17th 10, 05:25 AM posted to rec.aviation.soaring
Bastoune
Default Komet trailer interior floor refinish
I am considering refinishing the wood floor of my 80's era Komet
trailer over the coming weeks. The current plywood floor is in fair
shape but could use a coat of paint. I'd like to go for the painted
glossy look of those new trailers! The wood flooring is currently
stained...in some areas...
The paint specialist at Lowe's recommended an Oil Porch & Floor Paint
from Valspar:
http://www.valsparpaint.com/en/find-...rch-floor.html
This paint apparently works well on wood but is not recommended for
"automotive parking". Thus, I am wondering how good it will do over
time with the rubber wheels of the fuselage dolly.
Alternatively, I looked at Epoxy type paints systems typically
formulated for garage flooring. Probably durable but mainly designed
for concrete applications.
http://www.quikretecoatings.com/prod...r-Coating.html
Any suggestions on what has worked successfully in the past?
Old November 17th 10, 06:04 AM posted to rec.aviation.soaring
Grider Pirate
from Valspar:http://www.valsparpaint.com/en/find-...nterior/paint/...
for concrete applications.http://www.quikretecoatings.com/prod...gs/2-Part-Epox...
My floor could use refinishing too. I'll be interested to know what
you try and how it works out. In my trailer, the fuselage dolly
wheels had worn through at least one ply of the plywood floor. I
cemented 4" wide rubber baseboard to the floor where the wheels ride.
It seems to be holding up very nicely (about 2 years now).
Old November 17th 10, 02:03 PM posted to rec.aviation.soaring
Papa3
A guy in our club did the same thing several years back. IIRC, he
used marine paint, which is formulated for plywood and for wet
environments. Deck paint in particular is designed to be abrasion
resistant. One word of caution though - the stuff is usually
expensive (very). See for example: http://www.westmarine.com and
look for Paint under Maintenance.
Old November 17th 10, 02:38 PM posted to rec.aviation.soaring
KO[_2_]
A guy in our club did the same thing several years back. * IIRC, he
environments. * *Deck paint in particular is designed to be abrasion
resistant. * *One word of caution though - the stuff is usually
expensive (very). * See for example: *http://www.westmarine.comand
I have gone through two Komet trailer refinishes. For the fiberglass
top part I used silver epoxy based paint that I bought in home depot.
I used that to stop sunlight from going through the top and damaging
what was left of my LS4 gelcoat .
For the floor I used a marine gray paint that I bought at west marine
(any marine paint will do). I sanded the floor for improved
adhesion... and as Papa3 mentioned... that stuff IS expensive!
For the fuselage tray roller tracks, I used a L shaped aluminum
channel. That improved rolling the fuselage in and out and also
prevented further erosion of the wood, since both of my trailers were
developing groves, if not holes on that area...
Have fun!
Enrique
KO
Old November 17th 10, 04:54 PM posted to rec.aviation.soaring
4Z
Have fun!
Enrique
KO- Hide quoted text -
- Show quoted text -
You might look into 2 part rubberized epoxy used in some parking
garages. I used something called CM 1000 from Specialty Coatings in
Seattle on a marine application over plywood. Bulletproof, fairly
pricey, not sure about colors.
Old November 20th 10, 08:07 PM posted to rec.aviation.soaring
Bastoune
Thank you all for the tips about the floor paint. Marine paints should
hold nicely given the plywood substrate & humidity. Does anyone know
if the primer is a must have for these pricey marine paints?
Enrique - Regarding the silver epoxy paint, I assume that you painted
the inside of the fiberglass top cover. Why the silver pigments? What
type of application typically use these silver epoxy paints? I want to
make sure to pickup the right stuff.
Thanks!
Bastoune
Old November 23rd 10, 05:21 PM posted to rec.aviation.soaring
KO[_2_]
Thanks!
Bastoune
Bastoune:
You are right. I painted the interior of the trailer. My intention was
to block sunlight (UV rays!) from going through the top and further
damaging gelcoat. Friends suggested silver because allegedly it
"reflects" better, though I don't see how... I beleive any color will
do as long as it blocks sunlight.. silver just looked nice! ;-)
Hope this helps
Best regards
Enrique
KO
Komet trailer tires Robin Soaring 41 February 27th 10 06:27 PM
Trailer tires for old (1981) Komet Trailer [email protected] Soaring 3 May 13th 09 11:24 PM
Old Komet Trailer thermalrider Soaring 7 October 11th 08 05:13 PM
Komet Trailer Gas Springs P. Corbett Soaring 4 March 12th 07 12:30 AM
KOMET Trailer Cradle [email protected] Soaring 3 September 27th 04 05:33 AM
