Military jet landing at SJC?
Old November 21st 10, 03:17 AM posted to rec.aviation.piloting
Alexander Avtanski
Default Military jet landing at SJC?
Hello,
Today around 10:52am PDT (+/- a couple of minutes) I was in south San
Jose when I heard a very loud jet engine noise overhead. When I
looked up I saw something that looked like a F-18 on the SJC landing
path for 30L or 30R. It may have been a different plane - sorry, I
did not have my glasses - but it was definitely a military jet.
Did anybody notice this, and what was a military jet doing landing on
a civil airport?
Regards,
- Alex
Old November 21st 10, 10:06 AM posted to rec.aviation.piloting
John Clear
Alexander Avtanski wrote:
Hello,
a civil airport?
I didn't see anything on the SJC flight tracker. I watched 10:45am
to 10:55am.
http://sjc.webtrak-lochard.com/template/index.html
FlightAware doesn't show anything military at SJC or at Moffett either.
John
John Clear - http://www.clear-prop.org/
Old November 22nd 10, 03:55 PM posted to rec.aviation.piloting
Alexander Avtanski
This WebTrak thingy is a very neat tool. I was able to see the plane
in question:
http://avtanski.net/images/var/jet.png
As you can see, it turned out he didn't land on SJC, although from my
location (marked on the map) it looked right on the way to there. I
asked because I live in the area from over 10 years and this is the
first time I see something like that - just curious.
Regards,
- Alex
Hello,
Jose when I heard a very loud jet engine noise overhead. *When I
path for 30L or 30R. *It may have been a different plane - sorry, I
a civil airport?
I didn't see anything on the SJC flight tracker. *I watched 10:45am
to 10:55am.
John
John Clear - * * * * * * * * *http://www..clear-prop.org/
Old November 24th 10, 10:41 PM posted to rec.aviation.piloting
150flivver
On Nov 22, 9:55*am, Alexander Avtanski wrote:
in question:
*http://avtanski.net/images/var/jet.png
location (marked on the map) it looked right on the way to there. *I
Regards,
- Alex
Hello,
a civil airport?
to 10:55am.
John
John Clear - * * * * * * * * *http://www.clear-prop.org/
Many military fighters are restricted to landing at fields that have
barriers (cables) for an arrested landing if needed. They'll land at
fields without barriers under special circumstances such as an airshow
but they get a waiver from their command to do so.
Old November 30th 10, 04:30 PM posted to rec.aviation.piloting
John[_2_]
On 11/24/2010 5:41 PM, 150flivver wrote:
On Nov 22, 9:55 am, Alexander wrote:
in question:
Regards,
- Alex
On Nov 21, 2:06 am, (John Clear) wrote:
In ,
Alexander wrote:
Hello,
a civil airport?
to 10:55am.
John
Which military fighter is that? No problem for F-15, F-16, F/A 18, etc
to land without cables. I don't know if I've ever even seen cables at
military bases such as Aviano where fighters land daily. I'd be
interested in your source of information.
Old November 30th 10, 04:31 PM posted to rec.aviation.piloting
John[_2_]
True. Then again flight aware won't show most military flights anywhere
either.
Old December 2nd 10, 05:00 PM posted to rec.aviation.piloting
150flivver
On Nov 22, 9:55 am, Alexander *wrote:
in question:
Regards,
- Alex
In ,
Alexander *wrote:
Hello,
a civil airport?
to 10:55am.
Old December 2nd 10, 05:12 PM posted to rec.aviation.piloting
150flivver
in question:
Regards,
- Alex
In ,
Alexander *wrote:
Hello,
a civil airport?
to 10:55am.
John
barriers (cables) for an arrested landing if needed. *They'll land at
Which military fighter is that? * No problem for F-15, F-16, F/A 18, etc
to land without cables. *I don't know if I've ever even seen cables at
military bases such as Aviano where fighters land daily. *I'd be
Aviano definitely has barriers/cables for fighter use. *They are
visible on an overhead photo of the runway. *Some cables are recessed
into the runway and are elevated for use by the control tower. *Others
sit on top of the runway elevated a couple inches off the ground by
rubber donuts. *Normal landings touchdown past the cable to prevent
wear and tear on them or damage to underwing stores should the cable
pop up and contact them. *Fighters don't use the cable on land unless
there's a problem, so they can land at fields without them but for
safety's sake, they are generally operated at airfields that have
them. *I'm retired air force (1500 hours fighter) and never landed at
an airfield without barriers.
Here's the arresting gear available at Aviano: A-GEAR - Rwy 05 apch
end BAK-12 avbl O/R, 15 min PN. When Rwy 05 in use, BAK-12 (2463') and
dep end BAK-12s and E5 rigged. When Rwy 23 in use, BAK-12 (2402') and
Brutal F18 Landing On An Aircraft Carrier..............Military Video Clip Hansi Naval Aviation 5 July 18th 06 02:12 PM
Brutal F18 Landing On An Aircraft Carrier..............Military Video Clip Lufthansi Piloting 9 July 2nd 06 09:08 AM
Brutal F18 Landing On An Aircraft Carrier..............Military Video Clip Hansi Instrument Flight Rules 0 June 28th 06 11:07 PM
[sci.military.naval, rec.aviation.military] Lost Sunderland Flying Boat Found! Sunderland Military Aviation 0 April 4th 04 06:27 PM
Military jet makes emergency landing at MidAmerica Otis Willie Military Aviation 0 September 1st 03 02:28 AM
