Minimum Voltage for PowerFlarm
Old December 10th 10, 12:16 AM posted to rec.aviation.soaring
Brian[_1_]
Default Minimum Voltage for PowerFlarm
Looking at the specs for the Powerflarm, specifically the Brick
version I have two sources for power requirements. One says 10-30
volts and the other says 12-28 volts.
The portable will run on 6 Nicads which is 7.2 volts.
So does anyone know what the brick version requires as a minimum
voltage?
Brian
PowerFlarm rentals Lee[_11_] Soaring 20 November 22nd 10 09:23 PM
K6 Mux and PowerFLARM example systems Paul Remde Soaring 0 November 15th 10 05:01 AM
PowerFLARM questions Greg Arnold[_2_] Soaring 21 November 10th 10 04:05 AM
PowerFLARM Paul Remde Soaring 9 November 6th 10 04:30 AM
PowerFLARM Greg Arnold[_2_] Soaring 6 November 2nd 10 09:32 AM
