HUD
Old December 13th 10, 04:37 PM posted to rec.aviation.soaring
Mottley[_2_]
Default HUD
Any bets on how long it will be before these units find their way into
our cockpits??
http://www.slashgear.com/brothe-airs...ball-17103012/
Old December 13th 10, 05:23 PM posted to rec.aviation.soaring
kirk.stant
Default HUD
our cockpits??http://www.slashgear.com/brothe-airs...inch-screen-ri...
The key to a HUD (and the reason they are so expensive) is that the
image and symbology is focussed at infinity, so the eye doesn't have
to refocus to see it. If you just put an image 3 feet in front of the
eye and read it, you now have to refocus at long distance to see
anything else. Not much better than just looking in the cockpit, and
potentially much worse, if the eye is constantly looking at that close
image.
If this device allows the image to appear at infinity, then it has
potential.
Kirk
Old December 13th 10, 06:17 PM posted to rec.aviation.soaring
bildan
Default HUD
It's not a HUD it's a HMD or "Head or Helmet Mounted Display". It
belongs to a subset of these devices called "retinal display" which
projects a perfectly focused image onto your retina using microwatt
lasers which eliminates any presbyopia problems the user might have
and keeps the display in sharp focus regardless of where the user's
eye is focused. The "See Through" feature causes the projected image
to be overlaid on a real world view. The brightness is high enough to
work great in direct sunlight while using tiny amounts of power.
The University of Washington has been working on this concept since
the 1980's. Do they work? Absolutely.
For them to be practical in gliders, I think they would have to be
linked to a PTL (Push to Look) button on the stick which rotates the
projector into viewing position when pushed and rotates it out of the
way when the button is released.
These devices could eliminate the "screen real estate" and sunlight
viewing problems which has plagued glide computers.
One might imagine FLARM traffic data overlaid on the outside world.
Old December 13th 10, 07:21 PM posted to rec.aviation.soaring
Steve Rathbun
Default HUD
"Use the Force Luke"
http://www.youtube.com/watch?v=bXIqfHI0hQY
Old December 13th 10, 07:36 PM posted to rec.aviation.soaring
Andy[_1_]
Default HUD
That would require head tracking and probably a huge jump in system
complexity and cost.
Andy
Old December 13th 10, 08:40 PM posted to rec.aviation.soaring
bildan
Default HUD
Andy
Not a huge jump. PC gamers have a choice of several head tracking
systems which work with a player jumping about the living room.
Tracking a pilots head is less difficult since it need only track
pitch and yaw. Some IR LEDs on the glasses frame and a low-res video
camera would do it. It might even work with the "Track IR" system
supported by Condor Competition Soaring Simulator.
Head tracking would allow a very interesting 'augmented reality'
display of remote thermal detection data.
Old December 13th 10, 09:14 PM posted to rec.aviation.soaring
Jeroen
Default HUD
or you just buy one, second hand.......
http://www.segelflug.de/cgi-bin/clas...lassifieds.cgi add
8034
An old French development, nice, but not perfect
Variometer mit Head Up Display
Kategorie: Biete Instrumente Photo for Ad 8034
Anzeigennummer: 8034
Aufgegeben am: 06/12/2010
Kontakt: Rothhardt
Jena, TH
Telefon:
E-Mail: Antwort auf das Angebot
Web Site:
Finanzierung: Interesse an einer Finanzierung durch ein LBB
Finanzkauf Privat-Darlehen?
* Kredit-Rechner
* LBB-Tel: +49 170 5711758
* LBB-Fax: +49 30 24559454
* LBB E-Mail: bank-dresden AT lbb.de
Versicherung: Interesse an einer günstigen Flugzeugversicherung ?
Hier klicken!
Details
Biete "HUDIS" von Delta Instruments (Frankreich)!
Kopletter Rechner inkl. E-Vario und Sollfahrt aber ohne GPS.
Mit dabei ist ein Head Up Display auf LCD Basis zur Montage auf der
Instrumentenbrettabdeckung!
Voll funktionsfähig - inklusive Handbuch!
VB 300 �
Andy
Not a huge jump. Â*PC gamers have a choice of several head tracking
pitch and yaw. Â*Some IR LEDs on the glasses frame and a low-res video
camera would do it. Â*It might even work with the "Track IR" system
Old December 13th 10, 10:27 PM posted to rec.aviation.soaring
Andy[_1_]
Default HUD
pitch and yaw.
You proposed system, if it works, can only track head position
relative to the glider. For a conformal display system the derived
head pointing angles need to be earth referenced and independent of
the glider attitude. Tell me a bit more about how you would plan to
implement that in a non complex system.
Andy
Old December 13th 10, 11:10 PM posted to rec.aviation.soaring
bildan
Default HUD
pitch and yaw.
relative to the glider. *For a conformal display system the derived
Andy
True. The easiest way would be a MEMS IMU integrated into the glasses
or helmet but it would need frequent updates - possibly from horizon
detection and a magnetometer.
Old January 8th 11, 04:37 PM posted to rec.aviation.soaring
jcarlyle
Default HUD
For those interested in a sailplane HUD, I just ran across this:
http://en.wikipedia.org/wiki/Bionic_contact_lens
-John
