Rope Tension Meter for Auto Tow
Old December 19th 10, 11:52 PM posted to rec.aviation.soaring
Default Rope Tension Meter for Auto Tow
We at the Fault Line Flyers Glider Club in Briggs Texas want to build
or buy a tension meter for our auto tow operation.
Does anyone have experience that might be helpful.
Bill Snead
6W
Old December 20th 10, 12:26 AM posted to rec.aviation.soaring
Frank Whiteley
Bill Snead
6W
If you have a dedicated tow vehicle, you might look at this
http://www.coloradosoaring.org/think...ey/default.htm
Frank Whiteley
Old December 20th 10, 02:16 AM posted to rec.aviation.soaring
JohnElliott
Below is a link to the user manual for a Digital Tension gauge for
paragliding and hanggliding winches but it might be adaptable for auto
tow of sailplanes.
http://www.lemmen-engineering.nl/ima...Manual_DTM.pdf
Excerpt:
The Digital Tension Meter is specially designed for paragliding and
hangliding winches., however it can
also be used in other applications where force need to be measured.
The Digital tension meter is available
in two versions: single and double cable drum winches (DTM-S and DTM-
D).
The digital tension meter consists of three main parts: the analogue
panel display, the DTM box
(electronics) and one or two load cells. The DTM can be calibrated to
the application by means of three
buttons. After calibration the DTM stores the calibration values in
non-volatile memory.
The DTM-D automatically compares - after calibration- the measured
forces of the sensor inputs and
displays the highest force. The display value is updated every 25ms.
snip
Old December 20th 10, 05:06 AM posted to rec.aviation.soaring
Tim Taylor
On Dec 19, 6:47*pm, Marc Ramsey
I have no direct experience (though I'm currently designing a load cell
setup for a winch), but a 2000 lb capacity S-type load cell like this
one:
http://www.icscale.com/td112.htm
In combination with an indicator like this:
http://www.icscale.com/XK315Aind.html
Should do the job.
Marc
Marc,
What you describe was in the system that Udo built for auto launching
his ASW-27. I believe I have images of the system if anyone is
interested.
Old December 20th 10, 02:30 PM posted to rec.aviation.soaring
Gary Evans[_2_]
We used an auto tow system for launching Hang Gliders back in the Mid-
West. The vehicle hardware consisted of a small hydraulic cylinder
mounted on the rear bumper and a 5-inch diameter gauge mounted on the
hood with a CB antenna magnetic mount. They were connected with nylon
tubing and poly-flow fittings. We used this system for years without
any problems.
Old December 20th 10, 06:07 PM posted to rec.aviation.soaring
bildan
Bill Snead
6W
You can buy strain gauge based electronic tension systems with hand
held readout units either wired or wireless. They are sometimes
called "crane scales" or "dynomometers". Just Google "tension load
cell". You'll want a 0-2000 Lbf unit.
There are also clevis attached USB tension load cells which plug into
your laptop which come with appropriate software. The USB units are
nice since they are powered by the USB bus - just plug and play.
Old December 20th 10, 08:40 PM posted to rec.aviation.soaring
Craig[_2_]
Bill Snead
6W
held readout units either wired or wireless. *They are sometimes
called "crane scales" or "dynomometers". *Just Google "tension load
cell". *You'll want a 0-2000 Lbf unit.
There are others too. I've been looking for a similar inline load cell
and will probably purchase from http://www.futek.com/. I don't have
any relation to the company, but have been looking for a while and
their offerings appear to be pretty solid.
Craig
Old December 22nd 10, 04:18 AM posted to rec.aviation.soaring
Bill Snead
6W
and will probably purchase fromhttp://www.futek.com/. *I don't have
Craig- Hide quoted text -
- Show quoted text -
Great information
Thanks to all
Bill Snead
Old December 22nd 10, 06:27 AM posted to rec.aviation.soaring
Larry Goddard
" wrote in message
Bill Snead
6W
Great information
Thanks to all
Bill Snead
Just out of curiosity, where is one of the items placed in the system???
They look like a big "S". Where do you attach what?
Larry
Best Rope to purchase for Auto Tows? [email protected] Soaring 4 October 17th 10 04:23 PM
tow rope tazman Soaring 9 August 25th 10 03:30 AM
For sale: DG-600 17-meter and 15-meter wingtips Lars Peder Hansen Soaring 0 January 21st 07 07:18 PM
Winch tension meters - sources? [email protected] Soaring 2 January 7th 07 02:54 AM
11 on a Rope Peter Seddon Rotorcraft 0 May 27th 04 12:33 PM
