RT-395A transponder
Old August 13th 03, 12:46 AM
Steve
Default RT-395A transponder
My 28V transponder is being very slow to warm up lately and I can get a good
deal on another RT-395A but the guys says it is 14V. What would it take to
make this one work on my system. Thanks
Steve
Old August 13th 03, 05:57 AM
Aaron Coolidge
Steve wrote:
: My 28V transponder is being very slow to warm up lately and I can get a good
: deal on another RT-395A but the guys says it is 14V. What would it take to
: make this one work on my system. Thanks
: Steve
Your RT-395A transponder might be a 14V unit with a dropping resistor inline,
in the airplane's wiring to the transponder (don't laugh! They actually did
this!). You might want to remove it from your dashboard and see if it has
a voltage rating listed on it. Otherwise, call Airwich Avionics, they know
Cessna radios.
Aaron Coolidge (N9376J)
Old August 14th 03, 12:46 AM
mikem
Steve
There is only one transponder which works on 14V. In 28V
installations, a big dropping resistor is mounted on the rear of the
tray. If you are doing a slide-in replacement, no wiring changes
should be necessary.
MikeM
VHF & Transponder antenna Steve Home Built 1 December 6th 04 05:29 PM
Fixing the Transponder with Duct Tape and Aluminum Foil Ron Wanttaja Home Built 45 March 14th 04 01:18 AM
Transponder code switching Ken Pruchnick Instrument Flight Rules 30 October 12th 03 09:31 PM
Altimeter And Transponder Certifications - Dallas Dave Aviation Marketplace 0 September 20th 03 04:55 PM
transponder check? Russell Duffy Home Built 10 August 15th 03 12:36 AM
