The third digit on my formerly bullet-proof Narco AT-50 transponder has
suddenly started displaying incorrectly for ATC. Specifically, it seems to be showing as a "4" on their screens, regardless of what we dial it to in the plane. Thus, instead of squawking "1200" when we're VFR, we're squawking "1240"... What could cause this? Any recommendations on repair versus replacement? Thanks! -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
"Jay Honeck" wrote:
Any recommendations on repair versus replacement? I can no longer imagine having a transponder with four knobs. If you get one with sequential digital entry, you can leisurely scoff at all the Usenet arguments about the dangers of flipping through 7XXX codes... It's really a minor thing, but I also like the fact that my transponder displays pressure altitude. When I need to know pressure altitude, it saves me the trouble of futzing with the Kollsman knob. Jay, you fly one of the greatest GA airplanes ever designed (except for its notable lack of a pilot-side door), and it deserves nothing less than the best. http://www.garmin.com/products/gtx327/ http://www.bendixking.com/static/cat...ls.jsp?pid=142 |
"Craig Prouse" wrote:
If you get one with sequential digital entry, you can leisurely scoff at all the Usenet arguments about the dangers of flipping through 7XXX codes... It's really a minor thing, but I also like the fact that my transponder displays pressure altitude. When I need to know pressure altitude, it saves me the trouble of futzing with the Kollsman knob. Jay, you fly one of the greatest GA airplanes ever designed (except for its notable lack of a pilot-side door), and it deserves nothing less than the best. http://www.garmin.com/products/gtx327/ Amen. Next to the autopilot, the Garmin 327 is the best thing I've put in my airplane. -- Dan C172RG at BFM |
"Jay Honeck" wrote in message news:Tjy5b.345829$o%2.158911@sccrnsc02... The third digit on my formerly bullet-proof Narco AT-50 transponder has suddenly started displaying incorrectly for ATC. Specifically, it seems to be showing as a "4" on their screens, regardless of what we dial it to in the plane. Thus, instead of squawking "1200" when we're VFR, we're squawking "1240"... What could cause this? Any recommendations on repair versus replacement? Thanks! -- What a coincidence. My AT 150 pulled this stunt at the beginning of a trip from Texas to Las Vegas about a week ago. In my case, the third digit flipped back and forth between 5 and 1. The bad news is that it will likely get worse, to the point where ATC can only see you part of the time. That caused me to rethink flying into the very busy Las Vegas area, opting instead to park it at Kingman, AZ. At least we got to see the Hoover Dam again. Anyway, the good news is that mine was fixed locally for $65.00. It was described as being an "adjustment", but I forget what was adjusted. I could look at the invoice to refresh my memory. While I'd love a pushbutton Garmin, I'm too cheap to toss a fixable unit. To save you a phone call, Narco factory service is $95.00 per hour plus parts. 2 to 3 week turnaround. They have a factory reconditioned exchange program for $595.00. Also a 2 to 3 week turnaround. I think there are issues with replacing an AT 50 with a 150. Something about needing a 150R. Let me know if you want details about where I got mine done. Dick Meade |
Narco also has a 10% off web coupon for service if the radio is sent by the
owner. In the case of a Nav radio, you could get away with flying without the radio for a few weeks. A transponder in busy airspace is another thing altogether. Ask around at the local shops to see if you can find one that will look at it. Here in the Northeast, I've had good luck with The Radio Shop, which is located at Worcester Mass, for repairing Narco stuff. Like I said before, the shops will generally only fix what is wrong; they won't bring the unit up to the latest mod level, do a complete check on the unit, or warranty the entire unit. If I was looking at a repair that cost near the value of the transponder, I'd seriously consider getting a new mode S with plans to eventually connect it to a MFD for traffic. I don't think I'd spring for a new mode C only at this point, as I suspect we'll be getting gently nudged to go with mode S in the not to distant future. Fortunately, yours does not sound like an expensive problem (the tube is fine, it is the digital encoding that is the problem), just an inconvenient one. If you are on good terms with a local shop, you might be able to get a loaner while you send it in to Narco if your local shop can't fix it. Dick Meade wrote: "Jay Honeck" wrote in message news:Tjy5b.345829$o%2.158911@sccrnsc02... The third digit on my formerly bullet-proof Narco AT-50 transponder has suddenly started displaying incorrectly for ATC. Specifically, it seems to be showing as a "4" on their screens, regardless of what we dial it to in the plane. Thus, instead of squawking "1200" when we're VFR, we're squawking "1240"... What could cause this? Any recommendations on repair versus replacement? Thanks! -- What a coincidence. My AT 150 pulled this stunt at the beginning of a trip from Texas to Las Vegas about a week ago. In my case, the third digit flipped back and forth between 5 and 1. The bad news is that it will likely get worse, to the point where ATC can only see you part of the time. That caused me to rethink flying into the very busy Las Vegas area, opting instead to park it at Kingman, AZ. At least we got to see the Hoover Dam again. Anyway, the good news is that mine was fixed locally for $65.00. It was described as being an "adjustment", but I forget what was adjusted. I could look at the invoice to refresh my memory. While I'd love a pushbutton Garmin, I'm too cheap to toss a fixable unit. To save you a phone call, Narco factory service is $95.00 per hour plus parts. 2 to 3 week turnaround. They have a factory reconditioned exchange program for $595.00. Also a 2 to 3 week turnaround. I think there are issues with replacing an AT 50 with a 150. Something about needing a 150R. Let me know if you want details about where I got mine done. Dick Meade -- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759 |
Jay Honeck wrote: What could cause this? Any recommendations on repair versus replacement? This happened with my Bendix-King unit. My avionics tech fixed it as part of my 91.413 check - no additional charge. It was a bench repair and took him only a few minutes. George Patterson A friend will help you move. A really good friend will help you move the body. |
| Thread Tools | |
| Display Modes | |
| VHF & Transponder antenna | Steve | Home Built | 1 | December 6th 04 05:29 PM |
| A problem in the Military ? | Nick Jade | Military Aviation | 54 | March 15th 04 08:59 PM |
| Fixing the Transponder with Duct Tape and Aluminum Foil | Ron Wanttaja | Home Built | 45 | March 14th 04 01:18 AM |
| Garmin fixes moving waypoint problem -- almost | Jon Woellhaf | Instrument Flight Rules | 6 | November 28th 03 06:29 PM |
| Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance | [email protected] | Owning | 5 | July 22nd 03 01:35 AM |
