New small transponder
Old March 4th 11, 01:28 AM posted to rec.aviation.soaring
Dave White
Default New small transponder
This is the article from the EAA newsletter:
http://www.ksallink.com/?cmd=display...13&format=html
This is the manufacturer:
http://www.aaicorp.com
Wonder if they might consider adapting this thing to gliders?
Old March 4th 11, 01:57 AM posted to rec.aviation.soaring
Whiskey Delta
Manufacturer link is actually: http://sagetechcorp.com/
Old March 4th 11, 02:20 AM posted to rec.aviation.soaring
Martin[_5_]
Nope...the market is too small. I asked them at a trade show. It's
meant for UAVs. That market is small, too, in terms of volume, but
they can charge a lot...UAV makers are less price sensitive than
glider owners.
Old March 4th 11, 02:42 AM posted to rec.aviation.soaring
JS
Other than a few thousand dollars, what's the difference between their
"conventional manned installation" and "adapted to gliders"?
Old March 4th 11, 12:01 PM posted to rec.aviation.soaring
Nigel Cottrell[_2_]
At 02:42 04 March 2011, JS wrote:
This looks a lot like the Trig 21 which I have had fitted in a powered
plane for about 18 months and am very happy with.
http://www.trig-avionics.com/library/TT2xBrochure.pdf
This link should take you to their website.
Old March 4th 11, 12:49 PM posted to rec.aviation.soaring
John Smith
Am 04.03.11 13:01, schrieb Nigel Cottrell:
The TT21 is a class 2 transponder and therefore *not* suited for
gliders. If you choose to go with Trig, then do yourself a favour and
buy the TT22.
Old March 4th 11, 03:19 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Pro: the "power box" is about half the thickness of a Trig power box.
Cons: The power consumption is greater than a Trig according to their
data sheet, it's not TSO'd.
It would have to be several hundred dollars cheaper the Trig than to
appeal to me enough to dump my Becker, based on those pros/cons.
email me)
Old March 4th 11, 07:56 PM posted to rec.aviation.soaring
Darryl Ramm
email me)
Unlike the Trig TT21/TT22 the encoder is not built into the control
head, its a separate box that appears to be be bolted onto the RF
unit, its not clear if the same encoder can be used separately
connected via a cable or if third party encoders are supported. The
Trig scheme is really nice for gliders since you just run one control
cable from the panel area to wherever the RF box is mounted (hopefully
close to the antenna).
Sage is obviously a small company, their product data sheets seem to
show hand made prototypes and although things like "FAA TSO" show on
them but nothing from Sage is FAA/TSO approved. The January 2011 data
sheet says "We are accepting orders for non-
TSO certified Mode C transponders now." The difference in complexity
between a Mode C and Mode S transponder is enormous, so it would be
interesting to know the actual state of their Mode S product
development. Anybody know where their Mode S development is at?
The RF unit looks impressively small but I would have concerns about
the use of a surface mount SMA connector vs. the standard panel mount
TNC coax connector and how fragile this will be in practice, specially
if connected to a larger adapter. But a fine tradeoff for a small UAV
installation done at a UAV manufacturer.
Darryl
Old March 4th 11, 08:31 PM posted to rec.aviation.soaring
Darryl Ramm
email me)
Darryl
Also the list price on the Mode S transponder (which as mentioned is
not yet apparently available even for pre-order) is shown on their
price list as $3,587 which does not seem to be too competitive
compared to the current street price of ~$2,200 for the Trig TT21. Of
course comparing a future list price vs. current street price may not
be that useful. And $3,587 not say $3,600, curious price specificity
there.
Darryl
Transponder vs. Portable Transponder Detectors John Murphy Soaring 16 December 20th 08 07:25 AM
helo 1182 small - 1182 small.JPG (1/1) urbanwriter Aviation Photos 0 April 15th 07 09:06 PM
where to buy a small crank Charles McLaurin Soaring 1 May 12th 06 03:05 PM
Small Typo [email protected] Soaring 3 December 2nd 05 03:29 AM
Why are there no small turboprops? Thomas J. Paladino Jr. Piloting 59 June 8th 04 02:57 PM
