Long story short, I decided to go for broke and change out the two
front rubber washers/ O rings in my pitot tube in the tail of my ASW-20B. Years of dry pitot tubes going in and out had taken their toll on the washers and they were starting to leak. Reminder to all - lightly grease your pitot tubes so they keep the internal washers happy. OK, the front washer is easy as cake to replace. It is only about an inch into the tube and took less than 60 seconds to fish a new one into place. The tube by the way is the diameter of a pencil. Real fun to work in and try to see what you are doing with a small flashlight...not! The back washer has been a real joy so far. It is set back about 3-4 inches and there is a groove in front of where it is supposed to go where the hole to the TE line is. As I said in the title, I am about 8 hours now into trying to fish the new O ring back into the groove it needs to go in. I have a thin metal probe with a small 90 degree hook at the end that works well enough. I can eventually get a piece of the O ring to seat into the right groove but pushing the rest of the O ring into the groove has proven elusive. Anyone else had any success seating a new washer/o ring? I figure it has to work in the next 20 or so hours of trying - LOL. Thanks for any tips or tricks. Bruno - B4 |
![]() Anyone else had any success seating a new washer/o ring? *I figure it has to work in the next 20 or so hours of trying - LOL. *Thanks for any tips or tricks Use a piece of tubing or rod that somewhat precisely fits into the part of the socket you are trying to seat the o-ring into and use *that to push it into place. A dab of Superlube grease would go a long way here. Using a hook tool may damage the o-ring and/or put scratches in metal walls you want to be remain smooth. Also be sure you used the correct o-rings, which are going to be metric in this case. -paul |
I had a similar problems with a mud wasp in one of the club member gliders
making a home in the TE probe line what I did was disconnect the tube at the instrument panel and then connected a shop vac to the tail TE socket ...this way I didn't have to worry about expanding the vinyl tube and blowing it off the metal TE socket...I then ran a small weed whacker plastic string in and used a bucket of hot water at the instrument panel to wash the mud out...continued the vacuum until the line was again dry and all debris was removed....worked fine and no cutting the probe socket from the tail was ever needed.... this will likely work for you to get out any remaining broken rubber O rings out tim Please visit the Wings & Wheels website at www.wingsandwheels.com "Bruno" wrote in message ... Long story short, I decided to go for broke and change out the two front rubber washers/ O rings in my pitot tube in the tail of my ASW-20B. Years of dry pitot tubes going in and out had taken their toll on the washers and they were starting to leak. Reminder to all - lightly grease your pitot tubes so they keep the internal washers happy. OK, the front washer is easy as cake to replace. It is only about an inch into the tube and took less than 60 seconds to fish a new one into place. The tube by the way is the diameter of a pencil. Real fun to work in and try to see what you are doing with a small flashlight...not! The back washer has been a real joy so far. It is set back about 3-4 inches and there is a groove in front of where it is supposed to go where the hole to the TE line is. As I said in the title, I am about 8 hours now into trying to fish the new O ring back into the groove it needs to go in. I have a thin metal probe with a small 90 degree hook at the end that works well enough. I can eventually get a piece of the O ring to seat into the right groove but pushing the rest of the O ring into the groove has proven elusive. Anyone else had any success seating a new washer/o ring? I figure it has to work in the next 20 or so hours of trying - LOL. Thanks for any tips or tricks. Bruno - B4 __________ Information from ESET NOD32 Antivirus, version of virus signature database 5926 (20110304) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com __________ Information from ESET NOD32 Antivirus, version of virus signature database 5926 (20110304) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com |
Hang in there Bruno. I learned long ago that it would take me twice as long and cost me twice as much as it would had I hired a COMPETENT MECHANIC.
Still enjoy watching your videos on Youtube. Walt |
On Mar 4, 12:06*am, sisu1a wrote:
Anyone else had any success seating a new washer/o ring? *I figure it has to work in the next 20 or so hours of trying - LOL. *Thanks for any tips or tricks Use a piece of tubing or rod that somewhat precisely fits into the part of the socket you are trying to seat the o-ring into and use *that to push it into place. A dab of Superlube grease would go a long way here. Using a hook tool may damage the o-ring and/or put scratches in metal walls you want to be remain smooth. Also be sure you used the correct o-rings, which are going to be metric in this case. -paul Paul has got it right. Find a rod that fits or machine a piece of brass or similar to a close match and use that to push the greased O- ring in. You will need to work out whether the rear O-ring is easier to install with the front one out or not. You may need two different diameter rods. without seeing the mount its not possible to know. I know its a PITA, I've done this standing out on the ramp in the hot sun... Darryl |
On Mar 5, 12:44*am, Walt Connelly Walt.Connelly.
wrote: Hang in there Bruno. *I learned long ago that it would take me twice as long and cost me twice as much as it would had I hired a COMPETENT MECHANIC. Still enjoy watching your videos on Youtube. Walt -- Walt Connelly Actually I am expecting a video on this one as well.......;-) |
![]() Quote:
Walt |
On Mar 5, 2:02*am, marco wrote:
On Mar 5, 12:44*am, Walt Connelly Walt.Connelly. wrote: Hang in there Bruno. *I learned long ago that it would take me twice as long and cost me twice as much as it would had I hired a COMPETENT MECHANIC. Still enjoy watching your videos on Youtube. Walt -- Walt Connelly Actually I am expecting a video on this one as well.......;-) Thanks everyone for the words of encouragement. After close to 14 hours the little bugger finally popped into place! Wow! It is not as easy as it sounds. The O-ring is very deformed while in the must smaller diameter tube and is a real joy to get into that crazy groove 3-4 inches back. Well, at least I can testify that it is possible to do. I found a few tricks along the way that really helped at the end. Had I used those from the beginning it would have taken only an hour or two at the most. Live and learn. If anyone ends up in this situation in the future and needs to know the tricks, feel free to contact me. Looking forward to paying close attention to the Seniors this week! Good luck all and fly safe. Bruno - B4 |
Pitot tube for the antennae | Ernest Christley | Home Built | 12 | May 29th 06 05:05 AM |
Is that your pitot tube, or are you just glad to see me? | [email protected] | Rotorcraft | 0 | February 16th 05 08:16 PM |
Pitot tube question | Doc Font | Home Built | 2 | January 24th 05 04:28 AM |
pitot tube questions | Jim Burns | Owning | 10 | November 1st 04 10:01 PM |
pitot tube down | Emilio | Military Aviation | 16 | March 6th 04 11:37 PM |
