Aero 1500 as terminal for 302
Old March 23rd 11, 06:35 PM posted to rec.aviation.soaring
Andy[_1_]
Default Aero 1500 as terminal for 302
Some like to clear the Cambridge 302 flights logs periodically as it
is reputed to prevent the file security issue. This can be done with
a laptop PC using hyperterm or similar.
Since the my PDA is already connected to the 302 it would seem much
more convenient to use it than to connect a laptop.
I tried to get my Aero 1530 to talk to my 302 using the "connections"
interface but was not able to.
Anyone been able to make a 1500 series PDA talk to a 302 in a basic
terminal mode and, if so, how did you do it?
thanks
Andy
Old March 24th 11, 01:05 AM posted to rec.aviation.soaring
Frank Paynter[_2_]
is reputed to prevent the file security issue. *This can be done with
thanks
Andy
When you find out - let me know. I made a run at this problem last
year some time, but never found a useful solution.
TA
Used Compaq Aero 1500 units available Paul Remde Soaring 2 September 21st 10 05:50 PM
Wanted Power/data connectors for Compaq Aero 1500 PDAs Paul Remde Soaring 3 April 16th 10 01:23 AM
Seeking Compaq Aero 1500 Pocket PCs Paul Remde Soaring 0 March 25th 10 09:02 PM
Serial Connector for Compaq Aero 1500 series [email protected] Soaring 1 April 16th 05 02:58 PM
Compaq Aero 1500 Cradle PENN2P Soaring 1 October 18th 04 06:04 PM
