Solenoid valve for creating a tail ballast dump system...Lak17a
Old March 28th 11, 03:48 PM posted to rec.aviation.soaring
Sean Fidler
Default Solenoid valve for creating a tail ballast dump system...Lak17a
I need advise or recommendations on what solenoid valve's (type, model) would work best for creating a tail ballast dump mechanism. My glider, unfortunately, did not come with a mechanical release. My glider is in the shop getting an evacuation vent and break away tail wheel so the time is right to do this. As part of the current project we are removing the tail battery and adding lead in the boom to reduce the chances of a tail break in a ground loop. We can also easily use the tail battery wiring to power the solenoid switch.
Anyone have any experience or info to help me? Thanks in advance. I need to buy a valve today or tomorrow so pace is key!
Sean Fidler
Lak17a F2
248 977 7911
Ballast dump time Discus J. Nieuwenhuize Soaring 7 April 27th 07 06:56 AM
Brass Ball Valve,Gas Valve,Needle Valve,Angle Valve,Hose Bibcock Sale on good price valvetom Piloting 0 November 28th 06 03:25 AM
Dump valve for Ls4a Robert Harvey Soaring 0 November 20th 05 09:47 PM
Schemp Hirth water ballast dump valves tango4 Soaring 14 September 2nd 04 08:13 PM
Water dump valve rotary seal Bill Daniels Soaring 6 May 10th 04 12:02 PM
