Hydraulic Brake Problems Mystery!
Old March 29th 11, 04:46 AM posted to rec.aviation.soaring
John Sullivan
Default Hydraulic Brake Problems Mystery!
I too have experienced the problem you are having with my
Ventus which was manufactured in 2004. It took me a long
time to figure out what was wrong. Eventually I simply
worked my way through the system to discover that
everything free as it should be except for the master cylinder
plunger which was frozen in the body of the housing. I
removed the unit, withdrew the actuating plunger, cleaned it
and then put silicone grease on it. That was the fix! Now I
will grease it every year at the annual…
John Sullivan, UFO
Old March 30th 11, 06:00 PM posted to rec.aviation.soaring
Annemarie Hollestelle
On Mar 28, 10:46*pm, John Sullivan
Ventus which was manufactured in 2004. *It took me a long
time to figure out what was wrong. *Eventually I simply
plunger which was frozen in the body of the housing. *I
and then put silicone grease on it. *That was the fix! *Now I
John Sullivan, UFO
Please be advised that the European glider manufacturers use DOT4
(yellow) "car" brake fluid in their disc brake systems. If you use
the(red) "aviation" type mill spec. brake fluid in these systems all
your "O" rings will swell and your brake system will be seized !
Please check with the glider manufacturer before you add the wrong
fluid!
Ed Hollestelle, A1
Old March 30th 11, 06:56 PM posted to rec.aviation.soaring
Peter Scholz[_3_]
Am 30.03.2011 18:00, Annemarie Hollestelle wrote:
On Mar 28, 10:46 pm, John Sullivan
John Sullivan, UFO
fluid!
Ed Hollestelle, A1
Be careful, this is not true for all European gliders. E.g. my
Schleicher ASW24 uses Aeroshell Fluid 4, which is bases on mineral oil.
Using car brake fluid would ruin the system. The difference lies in
where the brake system comes from:
Aircraft brake system (Cleveland): mineral oil based fluid
Motorcycle brake system: DOT... car brake fluid
Peter Scholz
ASW24 JE
Old March 30th 11, 08:47 PM posted to rec.aviation.soaring
Andy[_1_]
John Sullivan, UFO
fluid!
Ed Hollestelle, A1
Peter Scholz
ASW24 JE- Hide quoted text -
- Show quoted text -
From what others have said on this group it's not quite that simple.
It seems some glider manufacturers chose to use a Cleveland wheel
assembly but mate it with a non aircraft master cylinder. The master
cylinder then forces auto style fluid to be used and that's
incompatible with the Cleveland caliper seals so they get changed to a
different type.
Of course the simple answer is to read the glider's maintenance manual
but I know that's a last resort
Andy (ASW 28)
Old March 30th 11, 09:42 PM posted to rec.aviation.soaring
James Thomson[_2_]
different type.
Andy (ASW 28)
The ONLY safe way is to read the manual! Source of the glider or wheel
caliper maker is not a safe guide to the correct fluid.
The ASK-21 uses Cleveland parts throughout - and red aviation fluid
The DG-505 uses a Tost (aircraft) master cylinder and a Cleveland caliper
(with changed seals) and DOT4 car fluid.
Tost offer a range of master cylinders which use DOT4, they then confuse
things by offering their own caliper (DOT4) and Cleveland parts for either
DOT4 or red fluid! Only your own handbook can tell you what to use.
Old March 31st 11, 02:55 PM posted to rec.aviation.soaring
seventripleone
The only safe way may be to look what's already in the system.
(Everything else than red color means .4 IMHO).
For Cleveland/Parker brake calipers delivered by Tost to non-
Schleicher manufacturers: they are ex-factory equipped with o-rings
for mineral/"Aeroshell" oil and "converted" to .4 (= o-rings
exchanged). These calipers receive a big red (removable) label that
says DOT4 and get a little "O" stamped to the outside (diam. ~ 5mm,
permanent) which may be hidden by other hardware when the caliper is
mounted to the glider.
Old March 31st 11, 04:00 PM posted to rec.aviation.soaring
Andy[_1_]
Absolutely not! Unless you are the sole owner of the glider since
new, and unless no one except you has ever maintained it, you have no
idea whether someone else has contaminated the system with the wrong
fluid.
Maintenance manual first, then if the color does not agree, a careful
review of the maintenance logs to see if the system has been
modified. If the color does not match and there is no record of
modification you could be in for a complete brake system overhaul.
Andy
Hydraulic brake problems Dick[_3_] Soaring 15 March 29th 11 07:31 AM
Bleeding LS4 wheel brake hydraulic system David Starer[_3_] Soaring 1 April 3rd 10 05:06 PM
hydraulic brake actuation Brad[_2_] Soaring 15 January 9th 09 06:46 AM
Hydraulic trailer surge brakes means no parking brake? [email protected] Soaring 11 March 18th 08 05:19 AM
AP: Navy Jet Has Severe Brake Problems Otis Willie Naval Aviation 0 August 6th 05 01:20 AM
