Shadin flowmeter problems - anyone else sees this?
Old October 31st 03, 04:03 PM
Steve Beaver
Default Shadin flowmeter problems - anyone else sees this?
Just a guess but EEPROM can be very slow indeed. Depending on the exact part
number, it may not even be possible to change a single location in the chip.
This means that you have to read the entire contents (or a large part) of
the chip, change the value you need to update and then write it all back
again. This is a real pain and can take several seconds to complete.
I would suggest you wait about a minute before turning off the device so
that it has time to go through this procedure.
Most programmer will display some thing like "Updating . . " while the
update is in progress and the "Done" when complete so that you know what is
going on.
Steve
"Peter" wrote in message
Hi,
I've had a Shadin Microflo for a year and a half, and it has what
looks like a hardware or software bug: after setting a new FOB figure,
waiting for it to save it, turning off power, turning power back on,
it has lost the new FOB setting and has reverted to the original FOB
setting which was there before I started to change it.
There is a strong correlation between how long the unit has been ON
(or OFF) since the FOB was set, and losing the data: the longer one
waits, the less likely it is to get lost.
I have now had FOUR of these changed (under warranty) and they all do
it. Sometimes one has to set the FOB (at fill-up time) ten times or
more before it "sticks" in the memory.
Shadin always respond with a standard reply asking for serial number
and other into and don't acknowledge any knowledge of this. They have
however confirmed that there is no battery which might go flat, so I
assume it is an EEPROM/FLASH, in which case (I have designed lots of
electronic products) it would appear a pretty serious "feature".
Has anyone else seen this?
Peter.
Return address is invalid to help stop junk mail.
E-mail replies to but remove the X and the Y.
Please do NOT copy usenet posts to email - it is NOT necessary.
more radial fans like fw190? jt Military Aviation 51 August 28th 04 05:22 AM
Shadin flowmeter problems - anyone else sees this? Bill Zaleski Instrument Flight Rules 2 October 31st 03 09:29 PM
Shadin flowmeter problems - anyone else sees this? Steve Beaver General Aviation 2 October 31st 03 09:29 PM
Shadin flowmeter problems - anyone else sees this? Bill Zaleski General Aviation 0 October 31st 03 02:22 AM
Shadin flowmeter problems - anyone else sees this? Bill Zaleski Owning 0 October 31st 03 02:22 AM
