G 103 Twin II weight troubles...
Old April 5th 11, 01:31 PM posted to rec.aviation.soaring
Eric van Geetsum
Default G 103 Twin II weight troubles...
The Twin II of our club has an empty weight of 415 kg wich, with a max.
permitable total mass of 580kg leaves a max. payload of only 165kg.........
Now we are trying to solve this problem because we want to ad an extra
20 kg of payload. so the payload can be increased to 185 kg
the options are to:
replace the big heavy mainwheel and tyre by new TOST or Beringer
lightweight aloy wheels
Grind down the very thick (GROB style) gelcoat to a minimum
Replace the battery for a LiPO type
Remove radio and electro sink-clim indicator incl all electrica wiring.
Remove all pollstry.
And then?????????
Someone recognises this problem and who encouterd a solution??
Eric
Fiberglass cloth weight vs 'finished' weight Fred the Red Shirt Home Built 12 April 5th 08 05:24 PM
troubles with ATC john hawkins Piloting 3 May 6th 07 06:30 PM
Glider Weight/Wing Loading and determing speed for best L/D for a given weight 65E Soaring 3 January 26th 06 10:26 PM
Weight of a Harley Evo / Twin-cam 88 for aircraft? Wright1902Glider Home Built 3 June 4th 04 02:56 PM
Empty/Gross weight Vs. Max. Pilot weight Flyhighdave Soaring 13 January 14th 04 05:20 AM
