Hello community,
imagine you have a plane (rented) with a build in 2-place intercom (sigtronics in this case) and want to give your passengers their own headsets, so you can communicate with them. It is not necessary for them to hear the radio transmissions you make, although, it would be nice (if legal ;-). What do you need? An additional portable 2-place intercom? A Y-cable extension? Thanks in advance for your answers. Regards Kai Glaesner |
"Kai Glaesner" wrote in message
What do you need? An additional portable 2-place intercom? A Y-cable extension? I purchased a 4-place portable intercom for this type of scenario. -- John T http://tknowlogy.com/tknoFlyer __________ |
![]() "Kai Glaesner" wrote in message ... What do you need? An additional portable 2-place intercom? A Y-cable extension? I have a 4-place sigtroncs portable that I used a lot. It seemed to work fine cascaded into the copilots mic/phone jack. |
Ron,
I have a 4-place sigtroncs portable that I used a lot. It seemed to work fine cascaded into the copilots mic/phone jack. So I guess you connected your headset to the pilots jack, and copilots and passengers to the portable? |
![]() "Kai Glaesner" wrote in message ... So I guess you connected your headset to the pilots jack, and copilots and passengers to the portable? Nope, I plugged all the headsets into the intercom. The only reason I used the copilots side is to keep the mess of cords out of my way. I used a portable PTT connected to PTT in on the intercom.... you may have to investigate whether this will work on your plane. On some planes I did this with I used the hand mike in. |
So I guess you connected your headset to the pilots jack, and copilots and passengers to the portable? I've found that it's much better to have all headsets plugged into the same intercom system. Otherwise you may find that your passengers can hear you, but you might not hear them. -- John T http://tknowlogy.com/tknoFlyer __________ |
John,
I've found that it's much better to have all headsets plugged into the same intercom system. Otherwise you may find that your passengers can hear you, but you might not hear them. I guess if I connect the portable to the pilot's jack and press the planes's build in PTT you can hear the whole group chatting while transmitting? |
I guess if I connect the portable to the pilot's jack and press the planes's build in PTT you can hear the whole group chatting while transmitting? Haven't tried it, but to prevent it from happening, I use my own PTT. ![]() -- John T http://tknowlogy.com/tknoFlyer __________ |
![]() "Kai Glaesner" wrote in message ... I guess if I connect the portable to the pilot's jack and press the planes's build in PTT you can hear the whole group chatting while transmitting? Depends on the intercom. I believe that on some if you don't use the PTT on the intercom itself, only the pilots mic goes thorugh (using their "fail safe" mode). |
Kai,
no. You connect the 4-place to the pilot side connectors and switch off the installed intercom. See www.ps-engineering.com and look for the manual of their Aerocom III. It's all described in detail, including use of an installed PTT switch. -- Thomas Borchert (EDDH) |
FS: Soft Comm ATC-4Y 4 place portable intercom | Jaysen Underhill | General Aviation | 0 | December 11th 03 09:42 PM |
FS: Soft Comm ATC-4Y 4 place portable intercom | Jaysen Underhill | Aviation Marketplace | 0 | December 11th 03 09:41 PM |
FS: Soft Comm ATC-4Y 4 place portable intercom | Jaysen Underhill | Instrument Flight Rules | 0 | December 11th 03 09:41 PM |
FS: Soft Comm ATC-4Y 4 place portable intercom, $75.00 | Jaysen Underhill | Aviation Marketplace | 1 | October 17th 03 02:04 AM |
FS: Soft Comm ATC-4Y 4 place portable intercom, $75.00 | Jaysen Underhill | General Aviation | 0 | September 4th 03 04:41 AM |
