O 2 system check
Old April 18th 11, 05:35 AM posted to rec.aviation.soaring
Default O 2 system check
We're getting ready to re-install the oxygen system in an old LS-3
Do I understand correctly that the aluminum tank needs to be pressure
tested, (hydrostatic test) every 5 years? Is the an FAA rule, or
recommendation of the tank mfrg's...or just common practice for the
refilling people?
Cookie
Old April 18th 11, 08:12 AM posted to rec.aviation.soaring
Alan[_6_]
In article " writes:
refilling people?
Cookie
The Department of Transportation specifies testing intervals and
procedures for pressure tanks; hence the DOT labeling stamped near the
neck of most tanks.
The testing interval is indicated in the DOT specification marked on the
tank. A good fill station will know what these are.
Given the problems discovered with SCUBA tanks made from 6351 T6 alloy,
which often resulted in cracking around the threaded area of the neck
after periods of sustained load (such as leaving them pressurized), it
would be prudent to have the tank carefully inspected by good inspectors.
If it requires a hydro test, and has not had one, a shop shop should not
refill it.
Alan
Old April 20th 11, 03:22 AM posted to rec.aviation.soaring
tested, (hydrostatic test) every 5 years? *Is the an FAA rule, or
refilling people?
Cookie
* The Department of Transportation specifies testing intervals and
neck of most tanks.
* The testing interval is indicated in the DOT specification marked on the
tank. *A good fill station will know what these are.
* Given the problems discovered with SCUBA tanks made from 6351 T6 alloy,
* If it requires a hydro test, and has not had one, a shop shop should not
refill it.
* * * * Alan
So I just pulled the O2 system out of the guy's trailer. The tank is
39 years old......the regulator is 41 years old.
I understand that some tanks have a service lifespan, but aluminum
tanks are "unlimited". I think this one is aluminum
Does it make sense to try to use this old stuff, or is it prudent to
purchase new equipment? Figure the cost of inspection, testing, and
possible regulator overhaul, maybe better to spend that money on new?
Cookie
Old April 20th 11, 03:36 AM posted to rec.aviation.soaring
So I just pulled the O2 system out of the guy's trailer. * The tank is
tanks are "unlimited". *I think this one is aluminum
purchase new equipment? *Figure the cost of inspection, testing, and
Cookie- Hide quoted text -
- Show quoted text -
Actually it is a steel tank 3AA
Cookie
Old April 20th 11, 04:23 PM posted to rec.aviation.soaring
mattm[_2_]
On Apr 19, 9:36*pm, "
Actually it is a steel tank * *3AA
Cookie
The tank may be worthwhile; if you hunt around your local yellow pages
you'll find
some place that does fire extinguisher testing that can do the hydro
test on
the tank. Around here that runs about $30. The 3AA steel tanks don't
have a
life limit, but the 3HT tanks do. The 3AL aluminum tanks also have no
life limit.
New tanks can be had for $50-60 but that's with the medical clamp
connector.
CGA-540 tanks cost more.
The regulator is likely one of the old Bendix regulators that mounted
on the panel.
They were beautiful regulators but they required an overhaul every two
years.
The overhaul kits aren't even available anymore.
You can get regulators and all the other accessories from all the
various
sailplane supply dealers. Some carry M&H, others have Aerox. There's
also medical regulators available if you hunt around on eBay. Beware
that
most medical cylinders have a different style connector, so you'll
have
to look for CGA-540 compatible connectors. I don't have any idea how
to tell which medical regulators are suitable for use in a glider, but
I will
point out that they do seem to be in common use.
I was going through this earlier this year trying to get ready for
wave camp
(I wound up flying someone else's plane actually). However, after
camp was
over I found a complete Aerox portable system for a pretty reasonable
price
on eBay. (Note that I didn't contact any wave this year so I'll be
using this
system in the future.)
-- Matt
Old April 20th 11, 05:36 PM posted to rec.aviation.soaring
noel.wade
On Apr 19, 6:36*pm, "
Cookie
Cookie -
See Matt & Darryl's comments about getting it Hydrostatic-tested, at
the very least. Some of those steel tanks last forever, others don't.
I've flown with a couple of old regulators. Then I bought a glider
that came with a Mountain High O2D1 system, and wow what a difference
a modern O2 regulator makes! Much lower cockpit workload, better
hypoxia protection (automatically adjusting for altitude, so you don't
have to worry about forgetting to do so), uses much less O2... Can't
say enough about it. The Mountain High systems are around $600 -
$700. Not cheap, but not terribly expensive when you consider its
"life support" equipment!
Take care,
--Noel
Old April 20th 11, 06:17 PM posted to rec.aviation.soaring
mattm[_2_]
Cookie
Cookie -
the very least. *Some of those steel tanks last forever, others don't.
I've flown with a couple of old regulators. *Then I bought a glider
a modern O2 regulator makes! *Much lower cockpit workload, better
have to worry about forgetting to do so), uses much less O2... *Can't
say enough about it. *The Mountain High systems are around $600 -
$700. *Not cheap, but not terribly expensive when you consider its
Take care,
--Noel
Just to extend to some excruciating detail (feel free to ignore if you
already understand this): there's 5 parts to the system: tank,
fitting, regulator, metering device, and user delivery device
(cannula,
mask, or pressure mask). The MH O2D1 is an automatic metering device.
Mine came with a needle valve and flow meter. Typical medical
regulators
and some aviation regulators have that built in, but usually they are
calibrated in L/min rather than flow required at which altitude (there
is a mapping if you know what you are doing). Flow rates depend
on the user delivery device; masks and standard cannulas require
higher flow rates since they flow whether you are inhaling or not.
Automatic meters detect your inhalation and deliver the oxygen
pulse at that point. Fancy delivery devices (Oxymiser cannula, e.g.)
can help by making use of a reservoir to store up the oxygen you
need from a slower constant flow.
Whatever device you use, it's a really good idea to get an oxymeter
to be able to measure your blood oxygen. I picked one up on eBay
for about $35 (new).
-- Matt
Old April 20th 11, 08:06 PM posted to rec.aviation.soaring
Grider Pirate
On Apr 17, 8:35*pm, "
refilling people?
Cookie
Hydrostatic testing is not expensive. A bottle failure, however rare,
would likely be fatal for anyone very near.
This link has useful information about the markings on the oxygen
tanks.
http://www.usamma.army.mil/assets/do...20Markings.pdf
Old April 21st 11, 12:56 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
I second the motion. Amazon also has them, starting at $23. Or get one
with alarms ($70 or so), or alarms and logging ($130), for very
reasonable prices.
Has anyone tried the alarm and logging units?
email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm
http://tinyurl.com/yb3xywl
- "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what
you need to know tinyurl.com/yfs7tnz
Old April 21st 11, 06:37 AM posted to rec.aviation.soaring
Grider Pirate
to be able to measure your blood oxygen. *I picked one up on eBay
reasonable prices.
email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarmhttp://tinyurl.com/yb3xywl
One step better - an oxymeter as a sensor for a Mountain High system.
Not Yet Available to my knowledge.
System Operation of Aircraft System [email protected] Instrument Flight Rules 1 October 12th 07 07:50 AM
Check it out [email protected] Aviation Marketplace 0 November 30th 04 10:35 PM
S-Tec System 20/30 Versus System 40/50 Marco Leon Piloting 3 November 9th 04 05:15 PM
New Check Law Greg Butler Piloting 51 October 16th 04 01:18 AM
Roving static system check A&P Javier Henderson Owning 1 March 28th 04 10:36 PM
