SeeYou 4.01 update?
Old April 20th 11, 12:12 AM posted to rec.aviation.soaring
JS
Default SeeYou 4.01 update?
You may want to delay installing this update.
Seems that the link for the update 4.01 you will be advised of at
startup actually links to the version 3.95 installer. The software
then becomes an unregistered version of 3.x.
Paul Remde has already contacted Naviter, but it's after business
hours there.
Old April 20th 11, 12:14 AM posted to rec.aviation.soaring
Paul Remde
Hi Jim and everyone,
Actually, I have now solved the issue. The issue only occurs if you let
SeeYou "automatically" upgrade you to version 4.01. It seems to be
downloading an old version 3.95. SeeYou version 4.0 had notified me that a
new version was available and asked if I wanted to upgrade to it. I
selected yes and it then linked me to the old version.
However, it works fine to quit SeeYou and then download and install version
4.01 from www.naviter.si.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
"JS" wrote in message
hours there.
Old April 20th 11, 12:10 PM posted to rec.aviation.soaring
Andrej Kolar[_4_]
Oops. One character wrong at the webiste. Problem fixed. Thanks.
Andrej Kolar
glider pilots use
www.Naviter.com
Actually, I have now solved the issue. *The issue only occurs if you let
SeeYou "automatically" upgrade you to version 4.01. *It seems to be
downloading an old version 3.95. *SeeYou version 4.0 had notified me that a
new version was available and asked if I wanted to upgrade to it. *I
4.01 fromwww.naviter.si.
Best Regards,
Paul Remde
*Seems that the link for the update 4.01 you will be advised of at
*Paul Remde has already contacted Naviter, but it's after business
hours there.
Jim- Skrij navedeno besedilo -
- Prikaži citirano besedilo -
SeeYou on a Mac Andy[_9_] Soaring 1 May 20th 09 07:42 PM
Seeyou NMEA to Winpilot/Seeyou Jean Soaring 4 June 3rd 06 12:38 PM
SeeYou v3.1 Tim Harrison Soaring 5 April 21st 05 06:48 PM
SeeYou 2.82...anyone try it yet? Stewart Kissel Soaring 4 January 3rd 05 10:31 PM
Update on Satellite Images for SeeYou David Starer Soaring 0 September 14th 03 11:36 AM
Copyright Š2004-2025 AviationBanter.
