2000km Distance Flight Underway Now (USA)
Old April 21st 11, 12:37 AM posted to rec.aviation.soaring
Kemp[_2_]
Default 2000km Distance Flight Underway Now (USA)
As of 3:30p, Gordon Boettger and Hugh Bennett flying a Duo Discus, are
on the third leg entering the Owens Valley.. Conditions are, as they
say in the meteorology world, SCREAMIN', as they've been at max speed
speed most of the time. Follow the flight on the spot page:
http://share.findmespot.com/shared/f...xei0EDRpqb 3q
There was a bit of a hiccup at Mono Lake on the 2nd leg, but they got
past that. Target landing is at least Winnemucca for about 2100km,
but with extra luck they can hit McDermitt for 2300km or so.
Kemp
Old April 21st 11, 01:03 AM posted to rec.aviation.soaring
Paul Cordell
speed most of the time. *Follow the flight on the spot page:
http://share.findmespot.com/shared/f...glId=03HUTo6Od....
past that. *Target landing is at least Winnemucca for about 2100km,
Kemp
Looks like a good Thermal day too
http://www.gbuapcd.org/dustcam.htm
Old April 21st 11, 01:23 AM posted to rec.aviation.soaring
Kemp[_2_]
Kemp
Yes, but only the cu in the WAY distance!
Old April 21st 11, 03:59 AM posted to rec.aviation.soaring
Tony[_5_]
outstanding!
Old April 21st 11, 05:07 AM posted to rec.aviation.soaring
Kemp[_2_]
On Apr 20, 6:59*pm, Tony wrote:
outstanding!
Gordon and Hugh are down safely at Winnemucca Airport. I've called
the FBO, Buster, and he's on his way out. Rick Walters is just
arriving now too.
Old April 21st 11, 07:54 AM posted to rec.aviation.soaring
Tuno
Unbuckingfelievable!!!
That was an incredible achievement, and a superlative soaring
achievement. Gordon and Hugh, I salute you.
Consider that 2100km is farther than the summed assigned task
distances of an entire regional contest!
Numbed
tuN7o
Old April 21st 11, 09:07 AM posted to rec.aviation.soaring
WOW!
Way to go Gordon & Hugh.
Mike Koerner
Old April 21st 11, 10:19 AM posted to rec.aviation.soaring
Darryl Ramm
outstanding!
Gordon and Hugh are down safely at Winnemucca Airport. *I've called
the FBO, Buster, and he's on his way out. *Rick Walters is just
arriving now too.
The big dogs just barked. Very impressive guys.
Darryl
Old April 22nd 11, 09:28 AM posted to rec.aviation.soaring
WaltWX
Fantastic flight... Congratulations Gordon and Hugh.. !!
Kempton alerted me around 3:30pm so I watched in awe the SPOT tracks
all the way to sunset.
Also captured some upper air charts, raobs and satellite photos. They
are all zipped up at around 9.8MB he
http://dl.dropbox.com/u/463771/Boett...r_20110420.zip
The satellite photos start around 2100Z or 2pm PDT and continue to
sunset. All of them are in the zipped file every 15 minutes for two
regions; one centered on Reno and the other Las Vegas. Converted them
to a 1fps video he
http://dl.dropbox.com/u/463771/VIS1KM_RNO_20110420.flv
http://dl.dropbox.com/u/463771/VIS1KM_LAS_20110420.flv
Amazing mountain wave clouds along practically the entire flight..
Walt Rogers, WX
Old April 22nd 11, 09:56 AM posted to rec.aviation.soaring
WaltWX
On Apr 22, 12:28*am, WaltWX wrote:
Fantastic flight... Congratulations Gordon and Hugh.. *!!
*http://dl.dropbox.com/u/463771/Boett...r_20110420.zip
to a 1fps video he
Walt Rogers, WX
Try these two video files if you can't view *.flv:
http://dl.dropbox.com/u/463771/VIS1KM_RNO_20110420.mp4
http://dl.dropbox.com/u/463771/VIS1KM_LAS_20110420.mp4
Walt, WX
Distance to Goal Flight in Texas ryanglover1969[_2_] Soaring 0 March 10th 10 10:45 PM
WGC Contest Day 3 Underway John Seaborn Soaring 0 June 8th 06 02:54 PM
Diamond Distance flight plan 303SAM Soaring 6 April 4th 06 01:21 AM
2000km in Nevada Kemp Soaring 6 May 20th 05 09:17 AM
UK - Declaring a free distance flight tango4 Soaring 1 August 22nd 03 10:01 AM
