My Colibri is interfering with my Microair. What do I need to do to
fix that? Boggs |
On Apr 25, 9:04*am, GARY BOGGS wrote:
My Colibri is interfering with my Microair. *What do I need to do to fix that? Boggs What exactly are the symptoms? What is the sound? Intermittent? What makes it better or worse? Interference will either couple through the antenna or power supply cabling. Power cabling is the most likely - you want to try ferrite chokes (preferably with the power wires wrapped though the choke several times) on the power leads to both devices placed close to each device. If antenna interference you can try checking connectors, make sure they look good and are connected firmly, try moving antennas away from cabling , try swapping the colibri/radio with somebody else and see if the problem goes away. Darryl |
Hi Gary,
There is a good chance that putting a ferrite tube on the power/data cable - near the Colibri - will solve the problem. If you can't get one at Radio Shack, I can sell you one. There a "clamp-on" versions that work fine. All Goddard cables I sell have ferrite tubes to avoid noise issues. Best Regards, Paul Remde Cumulus Soaring, Inc. "GARY BOGGS" wrote in message ... My Colibri is interfering with my Microair. What do I need to do to fix that? Boggs |
| Thread Tools | |
| Display Modes | |
| Mic for Microair 760 | Edwin Funk | Soaring | 5 | June 1st 09 04:47 AM |
| Microair 720 f/s | [email protected] | Soaring | 0 | October 26th 06 04:39 AM |
| Microair 760 | Ian K | Soaring | 2 | August 29th 06 01:59 PM |
| Microair 760 | Ian K | Soaring | 2 | January 21st 06 11:39 PM |
| Parts for sale Microair radio and Microair transponder | User | Home Built | 2 | December 15th 05 12:23 AM |
