Vibration is Citabria
Old December 9th 03, 09:32 PM
TIm Gilbert
Default Vibration is Citabria
We have a '67 KCAB that has a weird vibration from time to time. You can
feel it in the stick and seat. It is the worst around 2200-2400 rpm but
only in the air. On the ground it isn't noticeable. Oil analysis is fine
and the engine seems smooth. We've installed new motor mounts and
everything else on the airframe seems tight. One suggestion, from a local
KCAB expert, is that it is from the crossover exhaust. We've considered
having the prop balanced but figure that if it was a prop problem it would
occur all the time. Maybe a sticky valve but I would expect a sticky valve
to be 'cold engine' problem.
Any ideas?
Tim
N2606G
Old December 9th 03, 11:12 PM
Bela P. Havasreti
On Tue, 9 Dec 2003 13:32:06 -0700, "TIm Gilbert"
Perhaps a spark plug is not firing (intermittantly) under load at
altitude...? Happened to me in a '54 C-170B. With the smooth
6-cyl Continental, the problem showed up as a slight drop in RPM
without much vibration, but perhaps with a 4-cyl Lyc., the vibration
would be more noticable if one plug kept dropping out....
Bela P. Havasreti
Any ideas?
Tim
N2606G
Old December 10th 03, 01:34 PM
Dan Luke
"TIm Gilbert" wrote:
We've considered having the prop balanced but figure that if it
was a prop problem it would occur all the time.
No. An imbalance will be more noticeable at particular rpm, especially
higher rpm. You should have the prop balanced statically *and*
dynamically. If this has never been done, or not done in a long time,
you will probably notice a big difference, even if your immediate
problem has some other cause.
Dan
C172RG at BFM
Old December 10th 03, 02:57 PM
Stu Gotts
If that has no joy, check the lifters.
On Wed, 10 Dec 2003 06:34:09 -0600, "Dan Luke"
Old December 10th 03, 06:00 PM
One's Too Many
Don't discount the prop being out of dynamic balance. Our '71 Cessna
172 had a peculiar vibration from about 2250-2350 that would shake the
instruments in the panel and you could feel it in the floorboards and
thru the yokes. It was smooth as glass between 2000-2200 and also
above 2400. Getting the prop dynamically balanced all but eliminated
the vibration. It's still there, but vastly diminished now and very
tolerable. We only got charged about $150 to put a $1 AN bolt and nut
thru a hole in the flywheel for the balance weight :-) I wish the
vibration could have been completely eliminated, but the A&P who did
the balance says that with the particular prop we have, a Sensenich
74DM7S14-0-58 that was installed along with a new engine a few years
before we bought the plane, that it is common to have some minor
vibration in the neighborhood of 2300 rpms.
Old December 13th 03, 02:51 AM
Fly
I've balanced many props, and also owned a '75 8kcab for about 500 hours.
Key point of yours is the fact that the vibration isn't there all the time.
My gut feeling and psuedo-internet expert guess?
Airframe....but then maybe not.
If it is engine related, it'll be ignition or valve-train. But verify the
usual suspects also, compressions mag timing and so.
The hydralic units in the lifter bodies can go soft, bypassing more oil
pressure.
This changes the effective valve timing.
Do a mag check during cruise, this is where bad plugs or faults will show
up.
A mag check at 1700 basically just shows if the P-leads are grounded.
Also, make sure there is not interference with parts rubbing the airframe.
Exhaust pipes, hose clamps, baffling.....
Airframe, check for slop in the trim tab and other controls. Check the
bushings etc. Check the flying wire tension. Cable tensions etc.
Frankly, many aircraft can pass annual but could still benefit if time and
labor was spent going thru the tail section and getting everything up to
spec. Small annoying cockpit vibrations can come from many sources.
A Bonaza owner noticed his MP guage smoothed after removing an air skeg on
his tail.
I diagnosed trim-tab flutter in a Belllanca Viking that caused a cyclic buzz
to travel thru the airframe and up into the seats. Trim-tab had a half-inch
of slop.
A commanche had a shark fin antenna on top just aft of the baggage
compartment. It had been installed without a doubler. It fluttered 2-3
inches. It was cracking the skin.
Once, the aluminum strip above my 8KCAB windshield come loose, the rubber
nuts pulled out, and the vibration was scary!
How many pilots have really tried to look at the tail and other parts in
flight?
You gotta bend around and press your face up against the glass.
Get a buddy to fly formation for a looksee.
And if it hasn't been done....anyway definitely get a dynamic prop balance
check!!!
88% of prop aircraft can be improved.
Try to find a technician that has experience. Put two sensors on the
engine, fore and aft.
Adding a correction weight to a Lycoming ring-gear is an approved method,
but I have learned to shy away from that method unless it is the last
resort.
I just never been happy doing it that way.
It usually requires much more correction weight per unit of vibration and it
usually not in the optimum correction plane.
I charge $175-200. I don't do it for less. My $$$ equipment, experience
and service is what you get. If I can't help it, my fee is less.
And actually, the balance is is generally good for 600-1000 hours or maybe
more, so how does that prorate out?
let us know what you find out.
regards,
Kent Felkins
Felkins Aircraft
Tulsa Oklahoma
"TIm Gilbert" wrote in message
valve
Any ideas?
Tim
N2606G
Old December 13th 03, 04:29 AM
Troy Towner
Stuck valve.. Check that happens a lot..
Troy
"Fly" wrote in message ...
time.
pressure.
up.
his tail.
buzz
half-inch
of slop.
flight?
check!!!
resort.
it
experience
maybe
regards,
Kent Felkins
Felkins Aircraft
Tulsa Oklahoma
can
fine
local
would
valve
Any ideas?
Tim
N2606G
Old December 14th 03, 01:09 AM
TIm Gilbert
Just flew to breakfast this morning and the vibration was there for about
the first 10 minutes and then went away. After we ate, it was there again
for the first 5 minutes of flight and then kind of disappeared. I also
noticed strange things on the EGT. I'm now thinking it's a sticky value on
the number 4 cylinder (that's where the EGT probe is).
Can I just remove the valve covers and pull the prop through to check?
Tim
Old December 14th 03, 04:34 PM
Larry Smith
on
Tim
If it's sticking on the ground you can see it stuck with the valve cover
off. You can hear it too, i. e., blowby gases. We found an exhaust valve
stuck open by doing a differential compression test.
Read the material on stuck valves at Sacramento Sky Ranch's website. Very
informative.
Citabria 7ECA Exhaust Wanted Capt. Dave Home Built 2 February 2nd 05 05:20 AM
Vibration Testing Jim Weir Home Built 20 October 10th 04 08:22 AM
Citabria aerobatic harness Ed Wild Aerobatics 0 February 1st 04 06:38 PM
150hp Engine for Citabria Jim Igel Owning 1 September 9th 03 09:36 PM
Citabria Rolls to the Left John Shoemaker Owning 7 August 30th 03 07:40 AM
