Oudie not making valid IGC files
Old May 30th 11, 10:17 PM posted to rec.aviation.soaring
Tony[_5_]
Default Oudie not making valid IGC files
My last few flights have been with Oudie only and when uploading to
the OLC the IGC validation has failed. I also had a format issue with
my last flight and had to send it to the OLC help email. The response
I got said "I fixed the file, but it has no signature at the end, so
it will be invalid anyway. The contents stops with weird b-record,
hours of the preceeding b-records, therefore it could not be parsed by
the program." This may have been because the flight ended abruptly
when the battery on the Oudie died mid thermal. Although my flight
the day before was also invalid. Anyone seen this before?
Suggestions?
The flights:
http://www.onlinecontest.org/olc-2.0...htId=956800845
http://www.onlinecontest.org/olc-2.0...tId=1097355504
Old May 31st 11, 05:19 AM posted to rec.aviation.soaring
Paul Remde
Hi Tony,
Be sure to exit SeeYou Mobile when done flying. It saves the flight log and
adds the security data to the end of the file when you exit SeeYou Mobile.
To exit SeeYou Mobile, go to Menu Next Exit.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
"Tony" wrote in message
Suggestions?
The flights:
Old May 31st 11, 05:44 AM posted to rec.aviation.soaring
Tony[_5_]
On May 30, 11:19*pm, "Paul Remde" wrote:
Hi Tony,
Be sure to exit SeeYou Mobile when done flying. *It saves the flight log and
adds the security data to the end of the file when you exit SeeYou Mobile..
Best Regards,
Paul Remde
the OLC the IGC validation has failed. *I also had a format issue with
the program." *This may have been because the flight ended abruptly
when the battery on the Oudie died mid thermal. *Although my flight
the day before was also invalid. *Anyone seen this before?
Suggestions?
The flights:
http://www.onlinecontest.org/olc-2.0....html?flightId...
ah ha. pretty sure after the flight on saturday i just turned the
oudie off. on the other flight the battery died mid flight. that
explains it, thanks paul!
Valid OLC log out of SN-10b Jim Archer Soaring 4 June 11th 08 11:46 PM
Valid OLC log out of SN-10b Jim Archer Soaring 0 June 11th 08 06:43 AM
LX20-Secret Key Not Valid! Ken Ward Soaring 6 April 29th 06 08:22 PM
Enroute charts valid for use in Canada? Andrew Sarangan Instrument Flight Rules 3 June 3rd 04 06:34 PM
Airworthiness Cert Still Valid? Carl Orton Owning 12 February 13th 04 10:21 PM
