BGA Loggers
Old June 1st 11, 02:10 PM posted to rec.aviation.soaring
Rob Shepherd
Default BGA Loggers
Besides the LW and other more expensive data loggers, are there any other
loggers available that can be used for UK BGA badge claims?
Cheers
Rob
Old June 1st 11, 03:01 PM posted to rec.aviation.soaring
Nick Hill[_2_]
Default BGA Loggers
other
Cheers
Rob
Rob
See the following page:
http://www.fai.org/gliding/position_recorders
In the UK it looks like The QSTART BT-Q1000X and the FlyWithCE units.
Nick H
Old June 1st 11, 04:17 PM posted to rec.aviation.soaring
Peter Purdie[_3_]
Default BGA Loggers
Correct. Both The QSTARZ and FlyWithCe units are 'position recorders',
OK for Silver/Gold badges. You do need a barograph as well - a cheap
second user EWA will do, or even a clockwork Winter if you can find a
candle to smoke one (and an OO to seal it)..............
Currently £79.95 for the BT-Q1000X.
other
Cheers
Rob
Rob
Nick H
Old June 2nd 11, 06:34 AM posted to rec.aviation.soaring
Basil
Default BGA Loggers
But don't forget that if you use one of these then you need to carry a
barograph as well.
Basil
On Wed, 01 Jun 2011 14:01:21 +0000, Nick Hill
other
Cheers
Rob
Rob
Nick H
Old June 2nd 11, 05:27 PM posted to rec.aviation.soaring
Rob Shepherd
Default BGA Loggers
Thanks for the information all, very much appreciated.
Rob
barograph as well.
Basil
other
Cheers
Rob
Rob
Nick H
Old June 3rd 11, 12:43 PM posted to rec.aviation.soaring
urosp
Default BGA Loggers
barograph as well.
Basil
other
Cheers
Rob
Rob
Nick H- Skrij navedeno besedilo -
- Prikaži citirano besedilo -
This will most likely change quite soon. During last IGC meeting the
proposal was that users of those flight recorders will not need
separate barograph and that GPS altitude will be accepted. We can
expect some additional restrictions (because GPS altitude is not as
accurate). With this only world and national records and diamond
flights will be off limits for those devoices. And of course gliders
with motor – devices do not have engine sensor.
I believe that they are already good value, because for low price you
get device that is very simple to use and at least for flyWithCE
Flight recorder you get also flyWithCE Logbook software. If you are
not too demanding, then this software will be enough for you to also
check flights in Google Maps or Google Earth (also in 3D). For more
information check: http://www.flywithce.com/recorder.html.
Best regards
Uros
www.flywithce.com
Cost of IGC approved loggers [email protected] Soaring 33 February 14th 08 10:31 PM
OLC Loggers RN Soaring 8 November 17th 07 12:11 AM
Pressure Altitude in Loggers ContestID67 Soaring 2 June 12th 07 02:41 AM
IGC loggers again tango4 Soaring 3 July 14th 04 05:50 PM
Vanity Loggers? Steve Soaring 0 October 5th 03 03:54 AM
