The rudder waggle signal does not work
Old July 27th 11, 04:46 AM posted to rec.aviation.soaring
5Z
Default The rudder waggle signal does not work
On Tuesday, July 26, 2011 4:09:10 AM UTC-7, wrote:
Do you do a pre take off check list?
Yes
Do you "close and lock" ths spoilers as part of your pre take off
check list?
No. I use the spoilers to maintain rope tension and prevent over-running it if the tow pilot takes up slack a bit too fast. I then use it on my ship to help with aileron control at low speed, as do many others.
There are many nuances to glider operations, so one solution does not fit all situations.
What does work is currency, maintaining situational awareness, and not performing *immediate* programmed responses. ALWAYS think before you act. If pulling the release immediately after a wave-off will put me in danger, then I may just delay the release if I believe the tow pilot is in less danger than I am. Not all emergency responses can be pre-programmed, just ask an Airbus pilot.
-Tom
The rudder waggle signal does not work Pat Russell[_2_] Soaring 99 August 2nd 11 03:16 PM
The rudder waggle signal does not work 5Z Soaring 0 July 23rd 11 07:24 AM
Rudder waggle toad Soaring 33 November 21st 07 06:44 AM
DG Rudder AD - DONE! - Notes from my work ContestID67 Soaring 0 March 30th 06 08:36 PM
CH Rudder pedals, why don't they work wan2fly99 Simulators 2 January 12th 06 01:30 PM
