Randolph Wing Walk Compound
Old March 5th 04, 05:40 AM
Larryskydives
Default Randolph Wing Walk Compound
Alright, I need your comments on Randolph Wing Walk Compound. I am going to do
a few things to clean up my Arrow. One of the more noticeable things is the
wing walk. I have bought some Wing Walk Compound, and weather permitting will
probably put it on this weekend.
Any suggestions?
Any personal experiences?
Larry
Old March 6th 04, 11:29 PM
Jay Honeck
Any suggestions?
The stuff works well, as long as it's not too thick, and the temperature is
above 70.
Don't even think of "touching up" your wing-walk. Once you see how good the
new part looks, you'll do the whole thing.
I found no need to mask the edge -- just be careful, and you can go right up
to the already-existing edge. As with so many things in aviation, it's not
difficult, just time-consuming.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old March 7th 04, 01:20 AM
Bob Fry
Do you try to remove the existing stuff, or just goop it on over
whatever is there now? What prep do you do to the existing surface?
Old March 7th 04, 04:02 AM
On 06 Mar 2004 16:20:43 -0800, Bob Fry
Best thing I've found to peel it off with is a pressure washer.
If you really want to prep it properly, depending on what you find
under the old stuff, you would want to etch and alodine it.
TC
Old March 7th 04, 05:59 PM
Doug
I've seen them paint the top of the floats with paint and while wet
spread fine masonry sand on the paint. Brush it off, paint again.
Works great. Wipline uses this technique for the top decks on all
their floats. Comes off with stripper.
Old March 7th 04, 10:44 PM
Jay Honeck
None. I just painted over the wing-walk that was already there.
If done properly, wing walk is very thin. By the time you get around to
re-doing it, it'll be even thinner. (In my case, there were a couple of
pencil-eraser-sized bare spots.) The stuff paints on easy, and has stood
up well.
Jay Honeck
Iowa City, IA
Pathfinder N56993
"Bob Fry" wrote in message
more radial fans like fw190? jt Military Aviation 51 August 28th 04 05:22 AM
Osan’s 51st Fighter Wing to get its own coin Otis Willie Military Aviation 0 April 5th 04 11:44 PM
ANG Woman Wing Commander Doesn't See Herself as Pioneer, By Master Sgt. Bob Haskell Otis Willie Military Aviation 0 March 18th 04 09:40 PM
Props and Wing Warping... was soaring vs. flaping Wright1902Glider Home Built 0 September 29th 03 04:40 PM
Can someone explain wing loading? Frederick Wilson Home Built 4 September 10th 03 03:33 AM
