jet pollution penalties to begin
Old August 19th 11, 05:04 PM posted to rec.aviation.military,rec.aviation.piloting,alt.politics,alt.global-warming,sci.environment
Transition Zone
Default jet pollution penalties to begin
On Aug 15, 12:34Â*pm, "John Weiss" wrote:
Daryl wrote:
I don't know if jet contrails effect temperatures, and neither
do you.
You are not listening to the Scientists in this. Â*You are
listening to those that don't know about it. Â*I can come up with
tons of fantasies why it happened but the fact the temp raised by
3 degrees during the exact days that the Aircraft were grounded
and no other explanation can be found. Â*Cause and effect. Â*You
can't change physics.
Now, I have used scientific information why it happened. Â*Now it's
your turn. Â*Since it's not normal, you need to present your own
proof so I can view it.
So, you claim to have PROVEN that "jet pollution" causes global
COOLING, because LACK of "jet pollution" caused an almost-immediate
3 degree rise in global air temperatures.
So why is it that so many so-called environmentalists keep claiming
that same pollution causes "global warming"? Â*How is it that you
can so handily prove them wrong?!?
Anytime you cover a section of sky with something, it refracts the
rays of the sun back into space. Â*It's so simple, try and keep up.
When you remove that barrier it will cause a temperature increase.
Most of what the Jet Engines leave is water vapor and that is the
same as a cloud cover. Â*According to some, you should be cooler in
the sunlight than when a cloud cover comes over you, right?
Uh, no...
You just showed how "scientific" your analysis is [NOT] by showing us
you don't know the difference between refraction and reflection. Â*You
also totally dismiss any absorption and reradiation of heat or any
other interactions.
So, you have just proven you have absolutely NO IDEA of what net
effect, IF ANY, a contrail may have!
Ask the experts then: "Researchers: Contrails Add More To Global
Warming Than Airplane Emissions"
Mar 30, 2011 – "In a new paper, scientists say the condensation trails
left behind by aircraft could be causing more climate warming than the
CO2 emitted by all aircraft since the start of aviation".
►► -- http://www.npr.org/blogs/thetwo-way/...lane-emissions
Old August 20th 11, 01:12 AM posted to rec.aviation.military,rec.aviation.piloting,alt.politics,alt.global-warming,sci.environment
Daryl
On 8/19/2011 10:04 AM, Transition Zone wrote:
On Aug 15, 12:34 pm, "John wrote:
do you.
You are not listening to the Scientists in this. You are
listening to those that don't know about it. I can come up with
and no other explanation can be found. Cause and effect. You
Now, I have used scientific information why it happened. Now it's
your turn. Since it's not normal, you need to present your own
that same pollution causes "global warming"? How is it that you
rays of the sun back into space. It's so simple, try and keep up.
same as a cloud cover. According to some, you should be cooler in
Uh, no...
you don't know the difference between refraction and reflection. You
other interactions.
Actually, the exact opposite occurred right after 911. The Lack
of those contrails allowed an average temp increase of 3 degrees
across the United States and Canada. The long run might be an
increase but the short run (when they are abruptly missing)
causes a temp increase. After the flights were resumed, the temp
went back to normal.
http://tvmoviesforfree.com
for free movies and Nostalgic TV. Tons of Military shows and
programs.
Old August 20th 11, 03:10 AM posted to rec.aviation.military,rec.aviation.piloting,alt.politics,alt.global-warming,sci.environment
T. Keating
On Fri, 19 Aug 2011 18:12:08 -0600, Daryl
do you.
Uh, no...
other interactions.
?? -- http://www.npr.org/blogs/thetwo-way/...lane-emissions
As I recall the Daytime average temps were warmer and the nights were
cooler, so it averaged out close to a net zero. .
We'll probably see a lot less air traffic(and driving in general) in
10 to 15 years when peak oil drives the price of fossil fuels to
painful levels.
Old August 20th 11, 03:12 AM posted to rec.aviation.military,rec.aviation.piloting,alt.politics,alt.global-warming,sci.environment
T. Keating
do you.
Uh, no...
other interactions.
10 to 15 years when peak oil drives the price of fossil fuels over the
afford ability threshold for most families.
Old August 21st 11, 02:25 AM posted to rec.aviation.military,rec.aviation.piloting,alt.politics,alt.global-warming,sci.environment
Greg Russell
On Fri, 19 Aug 2011 18:12:08 -0600, Daryl quoted and wrote in
http://www.npr.org/blogs/thetwo-way/...8/researchers-
contrails-worse-for-environment-than-airplane-emissions
Actually, the exact opposite occurred right after 911. The Lack of
those contrails allowed an average temp increase of 3 degrees across the
May I please ask for a citation of your information source(s) for that
statement? I made the same request of someone who recently stated that
global avg. temperatures *decreased* after 9/11 due to the absence of
contrails. They were unable to respond.
Their statement was qualified as a increase of outgoing planetary
infrared radiation (due to lack of the H20 absorption and re-radiation in
all directions) relative to incoming visible-light albedo, certainly a
non-linear relationship.
This raises a very important question, and yet a very common one, which
usually goes unanswered: an average of precisely what information, and of
what time intervals? Hourly WMO (World Meteorological Organization) world-
wide station data of a week, a month, a year, a fortnight? ... and
relative to what time frame? Some private researcher's site-specific data
of the same time frame ? Your own data from your un-calibrated
instrumentation on your roof?
The long run might be an increase but the
short run (when they are abruptly missing) causes a temp increase.
After the flights were resumed, the temp went back to normal.
Again, I'll respectfully request a supportive citation, as the above
statement makes no physical sense on the face of it.
Old August 21st 11, 02:37 AM posted to rec.aviation.military,rec.aviation.piloting,alt.politics,alt.global-warming,sci.environment
Daryl
Repectfully, if you had done a simple Net Search you would have
come up with this same answer.
http://www.sciencedaily.com/releases...0808075457.htm
http://articles.cnn.com/2002-08-07/t...vis?_s=PM:TECH
On person pointed out out that the temp change in the day was up
while the temp in the night was down. This is caused by the lack
of the normal Contrail Water Vapors that the Airliners give off.
In the day, the lack of it allows less heat (rays) to be bounced
back. Hence the temp raises.
In the night, the lack of the contrails allows the escape of heat
hence the lower temp.
We are talking about water vapor and crystals. This is part of
the nature order of things. Mother nature uses it herself to
regulate temperatures. It's neither bad nor good. It just is.
programs.
Old August 22nd 11, 04:20 AM posted to rec.aviation.military,rec.aviation.piloting,alt.politics,alt.global-warming,sci.environment
John Weiss[_4_]
Repectfully, if you had done a simple Net Search you would have come
while the temp in the night was down. This is caused by the lack of
We are talking about water vapor and crystals. This is part of the
nature order of things. Mother nature uses it herself to regulate
OK...
What is the relative effect of contrails vs clouds? Is there a
measurable difference in worldwide temps on cloudy days vs clear days
in heavy air traffic areas?
jet pollution penalties to begin Transition Zone Piloting 0 August 19th 11 04:54 PM
Badge Distance Penalties 303SAM Soaring 7 June 11th 06 03:35 PM
Graduated Penalties (JJ needs a new project) Dave Nadler \YO\ Soaring 5 September 26th 03 07:47 PM
Graduated Penalties Andy Durbin Soaring 1 September 26th 03 01:53 PM
Boeing hit with harsh penalties Casey Military Aviation 4 July 29th 03 03:41 PM
